August 17, 20215 yr Hi All I need some guidance I recently bought Lifepo4 cell with voltage 3.2V - 3.65, low cut off 2.5v 320Amph 16 off. I wanting to buy the correct bmw looking at the Daly 200amp but some specs say charge voltage 44.8 and others 60.2 with the 60.2 be fine I will adjust the cut of voltage for the cells.
August 18, 20215 yr Author Hi below is the link to the BMS I would like to get its thee 200amp but parametes say https://banggood.app.link/F9WEXzfDOib but not sure if this is correct any with Daly BMS experience can shed some light it would be highly appreciated.
August 30, 20215 yr 21 hours ago, 87 Dream said: Hi John 2. This BMS is great value & the right product for your application. I use them in a few applications on my batteries & cannot say a bad thing about them yet. Bluetooth functionality, as well as good cable size for the right amount of amps. 87 @87 Dream are these bms voltage adjustable? Edited August 30, 20215 yr by Raj35
September 1, 20215 yr On 2021/08/31 at 12:53 AM, 87 Dream said: Hi Raj, unfortunately not in the sense of changing the parameters all together of lets say making a 24V BMS into a 48v system. The changes that can be made are the trigger parameters. Like at what cell individual you want protection etc. 87 @87 Dream thanks
