October 2, 20214 yr Hey everyone, Where can I find the official list of protocols that need to be set on the growatt inverter for the different brands of batteries. I have 2 Narada 48NPFC100 100AH batteries and cannot find anywhere which protocol number to set on my new SPF5000ES inverter. A list for most battery brands will be great as I am planning to buy at least 1 battery from each brand to test them for an upcoming project. Thanks in advance for advice and that evasive list or at the very least the setting for my 48NPFC100 batteries
October 22, 20214 yr Hi @WannabeSolarSparky I had same hardware (Inverter & Batteries) of you, in my case 3 Narada 48NPFC100 100AH and same inverter, and same problem :(, did you make it work?
October 22, 20214 yr On 2021/10/02 at 7:45 PM, WannabeSolarSparky said: Hey everyone, Where can I find the official list of protocols that need to be set on the growatt inverter for the different brands of batteries. I have 2 Narada 48NPFC100 100AH batteries and cannot find anywhere which protocol number to set on my new SPF5000ES inverter. A list for most battery brands will be great as I am planning to buy at least 1 battery from each brand to test them for an upcoming project. Thanks in advance for advice and that evasive list or at the very least the setting for my 48NPFC100 batteries Hello good day to you, I'm also looking for the South African Lithium battery protocol. If you ever get it I would like to try it in my setup as well. I've contacted the OEM, they told me they are not providing it.
October 23, 20214 yr Author 23 hours ago, Antonio de Sa said: Hello good day to you, I'm also looking for the South African Lithium battery protocol. If you ever get it I would like to try it in my setup as well. I've contacted the OEM, they told me they are not providing it. I have found the bms modbus protocol for the narada bms and am busy writing some code to extract the data and use it on my stats portal. As soon as I have it working I will share it with the community. I am so over all these guys keeping the code "secret" Data and full control must be free and easy to extract especially given the high prices we pay for the equipment
October 23, 20214 yr 1 hour ago, WannabeSolarSparky said: " As soon as I have it working I will share it with the community." I for one will be very interested. Thank you. "I am so over all these guys keeping the code "secret" Data and full control must be free and easy to extract especially given the high prices we pay for the equipment " Could not agree more . It's nonsense. Many companies have offered the following seemingly good excuses, but otherwise lame : 1. They don't have the resource to provide support and follow up queries once the protocol is released. Well what about a good document , like EG MODBUS protocol. Lazy and lame. 2 they too scared that they will provide you with a gun to shoot yourself: lame. If a certain voltage setting parameter can damage the product , then quite frankly it's a useless product . A good protocol driver will be developed to accept parameters only within a specified operating range. If the industry keep on going this route, they will do us , themselves harm in the long run. 1 hour ago, WannabeSolarSparky said:
October 23, 20214 yr 31 minutes ago, dropkick said: 1. They don't have the resource to provide support and follow up queries once the protocol is released. Well what about a good document , like EG MODBUS protocol. Lazy and lame. 2 they too scared that they will provide you with a gun to shoot yourself: lame. If a certain voltage setting parameter can damage the product , then quite frankly it's a useless product . A good protocol driver will be developed to accept parameters only within a specified operating range. If the industry keep on going this route, they will do us , themselves harm in the long run. I only have one option and that is to get the battery values from my Growatt inverters. as well as setting the charge, discharge and float voltage. So far it looks ok, see my values herewith.
October 24, 20214 yr Love it , you and others have inspired me to start rolling my own influxdb/grafana . It's seems to be a future proof direction , and I think worth the effort. Keep up good work. Cheers
October 24, 20214 yr Hello @WannabeSolarSparky, sorry for asking again, I tried with all protocols (01 to 49) but I didn't get it to work. have you managed to get it to work in lithium mode the inverter with the batteries?
November 21, 20214 yr Hi @WannabeSolarSparky, I have the same question as @Sebastian S. I have a Growatt SPF 5000TL with 1 x Narada 48NPFC100 100AH. If you managed to get the inverter to work in Lithium mode with the batteries, it would be great if you could share how
December 4, 20214 yr On 2021/10/22 at 11:15 AM, Antonio de Sa said: Hello good day to you, I'm also looking for the South African Lithium battery protocol. If you ever get it I would like to try it in my setup as well. I've contacted the OEM, they told me they are not providing it. Use Protocol 52 for LBSA batteries
December 4, 20214 yr 9 minutes ago, Wilco said: Use Protocol 52 for LBSA batteries After a long struggle my son managed to connect to the LBSA BMS battery, I think using Modbus with a Raspberry PI. We are now able to get all the necessary data from the battery's BMS. see attached, I'm still not connected BMS to the inverters, still using the inverter parameter settings to optimize battery usage, we will try sometime this weekend to connect the BMS. will let you know the outcome.
May 26, 20224 yr On 2021/11/21 at 8:23 PM, SolarConvert said: Hi @WannabeSolarSparky, I have the same question as @Sebastian S. I have a Growatt SPF 5000TL with 1 x Narada 48NPFC100 100AH. If you managed to get the inverter to work in Lithium mode with the batteries, it would be great if you could share how Hi, I got the same setup, have you managed to get the growatt inverter to work on the narada battery on Li mode?
June 4, 20224 yr On 2022/05/26 at 1:45 PM, Ree said: Hi, I got the same setup, have you managed to get the growatt inverter to work on the narada battery on Li mode? Sorry I ended up swapping the Growatt inverter for a Deye 5kW inverter towards the end of last year. For what it’s worth, BMS comms between the Deye 5kW and Narada battery does not work either, however the Deye does a much better job at estimating the battery SoC, though it is not perfect.
August 29, 20251 yr On 2021/10/02 at 7:45 PM, WannabeSolarSparky said:Hey everyone,Where can I find the official list of protocols that need to be set on the growatt inverter for the different brands of batteries.I have 2 Narada 48NPFC100 100AH batteries and cannot find anywhere which protocol number to set on my new SPF5000ES inverter.A list for most battery brands will be great as I am planning to buy at least 1 battery from each brand to test them for an upcoming project.Thanks in advance for advice and that evasive list or at the very least the setting for my 48NPFC100 batteries https://share.google/images/DbTf6k1IO4XAUN8US Edited August 29, 20251 yr by Peter zim
