4x 100ah AGM Battery settings
I have 4x 100ah AGM Batteries (mainly to get though loadshedding), grid tied.
I'm curious about the exact correct settings to charge on my Deye 5K and what voltage I should consider "empty, do not cross"
Typical loadshedding at night brings battery percentage down to about 86% / 49V after 2 hours
Does it make a big difference how fast this type of battery charges?
The charge current should preferably not exceed 0,2C (20A for a 100Ah battery).The temperature of a battery will increase by
more than 10°C if the charge current exceeds 0,2C
I would say 48.0V. With moderate discharging, that still leaves some capacity in the battery for reasonable life. That's for 20S (4S nominally 12 V modules) lead acid, basically any variation of lead acid.
Edit: at very low to no load, I'd say 49.0 V (12.25 V per module).
