January 3, 20179 yr Split the DB to run the stove, geyser (if not solar) and other heavy users directly from the grid. Then get a 3KW infini or rebranded infini for between about 12K and 17K IIRC. It is a true hybrid which can normally supply 3KW and can combine the grid to supply loads of more than 6KW for extended periods, like when the vacuum cleaner, hair dryer and a few other items are used simultaneously. Add up to 4500W of PV panels and a decent battery bank, e.g. 8 x Trojan T105-REs and you have a reasonably cheap set-up which should work seamlessly once configured correctly.
