Posted January 29, 20223 yr On a Sunsynk 5.5kW mppt I've got 5x Canadian Solar 395W. I'd like to use the 2nd mppt to fit 5 panels on another part of the roof but I'm a little confused about balancing. Is the balancing on 1 mppt or across both? So do I have to get another 5x 395W panels, or can I get 5x 450W JA Solar panels? (The part of the roof with the new panels can only fit 5; I could possibly add another panel to the setup on the 1st mppt)
January 29, 20223 yr as long as they are on separate mppt's, it does not matter, I have nine 355 watt panels on one mppt and six 540 watt panel on the second mppt
February 11, 20223 yr That's the advantage of having two separate MPPTs. Each can manage a different type of panels and different orientation to the sun from the other.
