April 27, 20224 yr 8 hours ago, Scorp007 said: Anyone tried those yellow polyester caps that are always fitted across the 220V input on desktop power supplies. I'm pretty sure it will have one or two of the already. Axperts do. See the part outline in purple (ignore other outlines): Is this the size you are thinking of? That capacitor is directly across AC-in. There are other, smaller capacitors to earth (blue in colour). Of course, Deye may be totally different. But they tend to follow the same practices.
April 27, 20224 yr 2 hours ago, Coulomb said: Is this the size you are thinking of? That capacitor is directly across AC-in. There are other, smaller capacitors to earth (blue in colour). Yes that is correct. Although a general item I just thought it is cheap to try and no harm if already fitted. Easy to do without opening a unit still under warranty.
February 3, 20233 yr Hi all There are two other posts on the same topic that is worth reading if you are still looking for a solution. These post are for Sunsynk inverters, however I believe the internals are the same. Kind Regards Wiggly
