April 4, 20224 yr Hi I had a Growatt 5kVA with a Pyltontech 2,4kWh battery. I've not added solar panels and replaced the Growatt with a 5kVA Sunsynk. My battery has been acting strange with the charge lights and run lights flashing. Any suggestion on how to fix this? Or is this even an issue?
April 4, 20224 yr Sounds like its operating as it should. When the SOC lights are flashing the battery is charging ,when they are on but not flashing the battery is discharging and when the SOC lights turn off the battery is idle.
April 4, 20224 yr 1 hour ago, MNK1234 said: Hi I had a Growatt 5kVA with a Pyltontech 2,4kWh battery. I've not added solar panels and replaced the Growatt with a 5kVA Sunsynk. My battery has been acting strange with the charge lights and run lights flashing. Any suggestion on how to fix this? Or is this even an issue? How is the battery comms configured? By CAN or using voltages?
April 4, 20224 yr Author 35 minutes ago, Nexuss said: Sounds like its operating as it should. When the SOC lights are flashing the battery is charging ,when they are on but not flashing the battery is discharging and when the SOC lights turn off the battery is idle. Ok because when the battery is charged, the SOC and run lights blink on an off. I would imagine this means the battery is idle? In the evening my use timer sets my battery to 100% (its too small to use at night)
April 4, 20224 yr Author 4 minutes ago, GTP said: How is the battery comms configured? By CAN or using voltages? CAN
April 4, 20224 yr 1 minute ago, MNK1234 said: CAN what does your LiBMS screen look like on the inverter?
April 4, 20224 yr 2 hours ago, mzezman said: what does your LiBMS screen look like on the inverter? It is set to Lithium, protocol 00. And limits are set to 40a for max charge and discharge Edit: My error. I thought i was replying to OP. Edited April 4, 20224 yr by GTP
April 4, 20224 yr Author 1 hour ago, mzezman said: what does your LiBMS screen look like on the inverter?
