Chris Dononion Posted February 24, 2017 Share Posted February 24, 2017 To all the specialist out there :-) since a couple of days my inverter switches @night from battery mode to grid mode and back. Please see Image attached. any Ideas ? any setup changes that i could do ? regards Chris Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted February 24, 2017 Share Posted February 24, 2017 Change setting 1 from SBU to SOL Chris Hobson 1 Quote Link to comment Share on other sites More sharing options...
Chris Dononion Posted February 24, 2017 Author Share Posted February 24, 2017 Thank you, SilverNodashi. Will do so just now..... hey, this forum really works. :-) Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted February 24, 2017 Share Posted February 24, 2017 The large number of cycles is due to your small battery bank. Quote Link to comment Share on other sites More sharing options...
Don Posted February 24, 2017 Share Posted February 24, 2017 22 minutes ago, Chris Dononion said: any Ideas ? any setup changes that i could do ? I am not so sure. He is on grid then it goes to battery and then immediately back to grid again. That looks more like a grid problem to me. I would set setting 3 to APL mode. Edit. I read it wrong. He stated from battery to grid and then back again, sorry. I just looked at the graph and assumed he was in grid mode. Quote Link to comment Share on other sites More sharing options...
Don Posted February 24, 2017 Share Posted February 24, 2017 27 minutes ago, Chris Hobson said: The large number of cycles is due to your small battery bank. Very small, as it only runs off batteries for about a minute and goes back to grid. Charges back to 100% in about 10 minutes then goes back to battery mode and repeats the cycle? That does not make sense to me. Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted February 24, 2017 Share Posted February 24, 2017 3 minutes ago, Don said: Very small, as it only runs off batteries for about a minute and goes back to grid. Charges back to 100% in about 10 minutes then goes back to battery mode and repeats the cycle? That does not make sense to me. You're right Don. I did not look at the timeline. Only other thing I could think of is Program 12 and 13 settings are too close to each other. Perhaps set Program 13 to 57V. Quote Link to comment Share on other sites More sharing options...
Don Posted February 24, 2017 Share Posted February 24, 2017 7 minutes ago, Chris Hobson said: Only other thing I could think of is Program 12 and 13 settings are too close to each other. I agree. Maybe @Chris Dononion can post the rest of his settings, that would help a lot. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 24, 2017 Share Posted February 24, 2017 Looks to me that the battery bank is to small or damage. Or back to grid settings is to high. Maybe try and drop it a bit Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted February 24, 2017 Share Posted February 24, 2017 2 minutes ago, Don said: I agree. Maybe @Chris Dononion can post the rest of his settings, that would help a lot. Hi Don here are Chris D's settings Quote Link to comment Share on other sites More sharing options...
Don Posted February 24, 2017 Share Posted February 24, 2017 12 minutes ago, Chris Hobson said: Hi Don here are Chris D's settings Thanks Chris, I had a look at those figures. I am not sure if he has changed them since then. If not, that is the problem with setting 12 and 13 at the same voltage level. That would really confuse the inverter and cause it to go from battery to grid and back again at very short intervals. Quote Link to comment Share on other sites More sharing options...
Engr naeem Posted May 9, 2017 Share Posted May 9, 2017 some times thing are hilarious... Quote Link to comment Share on other sites More sharing options...
malek94 Posted July 30, 2017 Share Posted July 30, 2017 Chris settings is very good Quote Link to comment Share on other sites More sharing options...
