May 20, 20224 yr Good day. We had a rainy few days and its still raining. How do I charge my batteries with Grid power just to ensure I have enough power for loadshedding. I have a 8kw Sunsynk inverter and 3 Hubble 5,5kwh batteries. Thanks in advance.
May 20, 20224 yr Use the system mode (timer) screen, set desired battery SoC for the desired time, tick "Grid" and voila!
May 20, 20224 yr You can also untick the "Use Timer" in system mode, the batteries will then fully charge with grid if solar is not available.
May 20, 20224 yr Don't you need to change settings on the battery screen as well to allow grid charge.
May 22, 20224 yr Morning I got Li batteries SA how do I do that and how do I change the warning to Yes?
