wimsza Posted July 20, 2022 Share Posted July 20, 2022 Hi We have installed a Sunsynk 8Kw Hybrid with 5Kw panels and 3 x Pylontech UP5000 (to be upgraded to 3 as soon as available) All load, except for Geysers and Aircons are on essentials, with a CT coil facing correctly from the grid. There is also legal feedback to the grid. Although the feed to the inverter is connected to grid-earth, when the change over switch is set to inverter all essential loads are without earth. When set to grid, earth is present. Question: Do I need to install an earth-spike to the inverter, a relay or what is the solution. Quote Link to comment Share on other sites More sharing options...
Derek Ramos Posted July 20, 2022 Share Posted July 20, 2022 I think you are talking about earth/ neutral bonding. Quote Link to comment Share on other sites More sharing options...
wimsza Posted July 20, 2022 Author Share Posted July 20, 2022 When you put a plug tester on, it shows live and neutral but no earth (btw RCD does not trip) When switched to grid power plug tester shows earth as well Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted July 20, 2022 Share Posted July 20, 2022 Exactly what is described in the video. Having a floating Neutral is dangerous and something that you should get sorted out. Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted July 20, 2022 Share Posted July 20, 2022 1 hour ago, wimsza said: When you put a plug tester on, it shows live and neutral but no earth (btw RCD does not trip) When switched to grid power plug tester shows earth as well The RCD is working correctly. If the current through L and N does not balance out only then should it trip. Based on those that have no E connection. Quote Link to comment Share on other sites More sharing options...
