SunSynk APP vs Inverter
54 minutes ago, HowTo said:
Has someone come across this problem. Who do you belief?
If someone knows how to rectify pls reply. What is broken.
Belief your inverter,
The app has a few bugs lately, all I can say is be patient these things take time with software development. Should sort itself out once the developer have sort the issue.
If you look at the SOC APP vs Inverter you will see the difference/
No hard feelings. It worked ok then all of sudden this morning belly up.
Which Batteries/BMS are you using and quantity. These are important points of information, to allow any assessment or correlation to similar issues.
But as Suly mentions above, Inverter is the goto source for true reading.
