kWh usage before and after Solar installation.
7 hours ago, JayMardern said:
Yes! Low-flow/low-pressure roses are absolute magic; we use them on both showers.
Even under the cooler weather this past week, the thermostat trick has held up nicely.
Our issue is that select family members like to spend longer than they should in the shower as part of their daily unwind process; wasting both water and energy in the name of 'relaxation'. I'd complain bitterly to them - if I wasn't one of them!
Is there a way to get to the geyser supply valve? Time to trim the hot water supply with the excuse somebody spent to long under the shower. LoL
At a time I wanted to build a plc setup, flow meter starts the process, after 10min the solenoid on the hot water supply will close. It will open again after lets say 15min for another 10min etc. But my plan was sort of enough of a deterrent to shower faster. But he still opened the water to a roaring waterfall even with a flow restrictor in. It would have been nice to use a flow meter to close the valve after lets say 30 liters of hot water, the user can decide 10min at 3 liter per min or 3 minutes at 10 liter per minute.
But now he stays in his own place and pays for everything himself and now he showers in record time.
Edited by Vaal
  • Replies 77
  • Views 19.5k
  • September 2022 in JHB South has been an excellent month for Solar PV - my best month so far (system installed in Nov 2021). I had a 666.7kW of load, with only 16.9kWh coming from the grid. Most of
  • Not sure I would recommend switching off fridges/freezes due to possible food issues. When the device comes on, it will need to run for a while to get the temperature back to the thermostat setting,
  • Carl Anthony
    Carl Anthony
    Hi all...   Thought I'd share my usage stats, system was installed and online from 26 May 2023. System info: 12 x 550w Longi Panels (North Facing) 2 x 5kVa Sunsynk Inverters 1
On 2023/10/02 at 5:45 PM, Carl Anthony said:
So coming back to the original topic of the thread 😝
September, best month so far in terms of grid usage…also with warmer temps of late I am now getting away with running the 4kW geyser for only 90min early mornings.
Your solar PV is rocking !!! That’s a lot of production
