November 1, 20223 yr Hi guys. I have a 5kw inverter recently installed. I was trying to set password then it locked me out. The inverter now requires a 5 digit password and I have looked through the manual and can’t find it. Anyone who can assist please. Much appreciated
November 2, 20223 yr 17 hours ago, Kudah said: Hi guys. I have a 5kw inverter recently installed. I was trying to set password then it locked me out. The inverter now requires a 5 digit password and I have looked through the manual and can’t find it. Anyone who can assist please. Much appreciated If it’s a screen lock then the password has to be generated directly from Sunsynk.
April 23, 20233 yr Hi Kudah I have a 8kW inverter and seem to be having a similar problem to what you had. Did you manage to get the pass code that it was requesting? If yes, where did you get it please? Thanks
May 30, 20233 yr how long it took to get the 5 digit pass code goys? The manual is horribly shit, it spoke about 4 digit codes? 7777/9999/1234 but not a 5 digit code Edited May 30, 20233 yr by CCM
June 19, 20233 yr On 2023/04/23 at 9:57 AM, Rockster said: Hi Kudah I have a 8kW inverter and seem to be having a similar problem to what you had. Did you manage to get the pass code that it was requesting? If yes, where did you get it please? Thanks
August 6, 20233 yr Good morning! After update my grid settings are locked 🔒! I need to change the grid frequency bandwidth. Does someone know how to unlock? Password? Thanks for your help!
September 5, 20233 yr On 2023/05/30 at 3:04 PM, CCM said: how long it took to get the 5 digit pass code goys? The manual is horribly shit, it spoke about 4 digit codes? 7777/9999/1234 but not a 5 digit code 7777 worked for me, thanks.
October 11, 20232 yr my 16kw single phase inverter is blocked. It doen't need 99999 anymore. It only said try to reset after 00:00:00
March 23, 20242 yr On 2023/10/12 at 12:52 AM, Simon Mavhungu said: my 16kw single phase inverter is blocked. It doen't need 99999 anymore. It only said try to reset after 00:00:00 Hi Simon, did you manage to solve the blocked issue? having the same issue this side.
May 20, 20242 yr After waiting I emailed [email protected] they asked Invoice of the product/prove of purchase.I then send it to them. and that was it after they send me the 6 digit code.
