Hi! I'm Gianfranco I'm new to solar and would like to know which battery is best between shoto and Hubble my installer quoted shoto for me and I see on forum thay it has comms problems kindly advice
Hubble is quite popular on this forum. I have no experience with these 2 but if i were to buy one, i would go with Hubble.
What inverter has been selected?
The important thing here is the combination of inverter and battery. Not all batteries offer comms with all inverters. If the installer can reassure you that the Shoto has comms with the inverter that is selected then you can relax on this issue.
shoto and Hubble
I don't have either, but the Shoto as far as I know is LiFePO4 and the Hubble is NMC LiIon, personally I will not be using NMC LiIon since they are more temperature sensitive, from what I can see, do some more research and then decide... maybe also get your installer to confirm and maybe demonstrate at another installation he's done, that the Shoto will communicate with whatever inverter/charge controller you are intending to use with it...
