Axpert MAX II 8K BMS problem with Pylontech
  • Replies 54
  • Views 12.6k
8 hours ago, pongo said:
So, my assumption that this is modbus was wrong.
yes , you are correct . I myself referred to this implementation before as being Modbus RTU compliant , which it is not . Its not unlike Modbus , actually only subtle differences, but different nonetheless.
My conclusions are:  I cannot use modbus, I have to implement directly LIB serial protocol on my own.
Correct , I have implemented this protocol directly from the EASUN protocol document which is referred to elsewhere in the thread. For the record , the EASON document also actually does not claim it to be Modbus.
Just a random though, I had issues with asserting the read write pins on the 485 transciever. I would set it high to write my data then set it low after the serial.write.  Problem is that serial.write is non blocking and buffered so I was asserting the read write pin before all the data got out. one easy thing to do was a stream.flush() or Serial.flush() just to test. This is a blocking call and only returns once all the data is gone. I don't like blocking code so after that I implemented a buffer check to see if the buffer is empty before switching the transciever back to read mode. Even then it seems bits were still in flight so I still issue a flush but at least this way it keeps the blocking time to a minimum.
A very simple hardware hack, if hardware mod is feasible, is to assert the control line when the TX line goes low.  Screenshot_20230514_080358.thumb.jpg.a2ddcea53f4b6a18d3eb7475eacde4bd.jpg
One transistor is used to do required level inversion.
That's a great suggestion. I had toyed with that idea but stupidly worried about "what if you are sending a low bit, then the transceiver is not active" but upon reflection now, deactivating the transceiver would be equivalent to sending a low bit.
Thank you.
