May 4, 201511 yr So this Lithium battery is taking the battery market by storm. But is It really that good compared to Lead Acid ? I have been buying Lead Acid batteries that offer 400 cycles at 100% DoD.
May 5, 201511 yr Yep the supplier is currently out of stock ...next batch arrive end of next month. I might be one of them getting a batch. The specs are really good. In the past been used only in EV's
May 5, 201511 yr Author Im also interested in buying a few. Where you ordering yours from Mike, and do you have a spec sheet ?
May 6, 201511 yr distributors are a company called Freedom Won. Lead Acid vs LiFePO4 for PV Hybrid and Backup.pdf Superior Lithium Iron Phosphate (LiFePO4) Cells - the next Generation of Energy Storage 28_04_2015.pdf
July 26, 201511 yr The lithium batteries I think is the future, but they are still very expensive and a bit complicated. From what I can see they also have a built in charger, since equalisation is very important and different from other batteries. Didn't know there was a proper lithium battery available here yet...
May 31, 201610 yr On 5/5/2016 at 0:12 AM, Soviarc said: Does anyone have experience with the Freedom Won or Tesla Powerwall packs? Not yet.
