January 17, 20233 yr For the life of me I can't find the post(s) showing busbar installation for paralleling batteries. Please help with some links.
January 17, 20233 yr Basically a busbar is a copper plate. You connect all + terminals to one copper plate and all the - terminals to another copper plate. Then from there you take a cable to the inverter. Here is an example of one: Solarwize 1000A Bus Bar Combiner Box 10P
January 18, 20233 yr On 2023/01/17 at 11:19 AM, swazz99jhb said: For the life of me I can't find the post(s) showing busbar installation for paralleling batteries. Please help with some links. Here is a great example:
January 19, 20233 yr Author On 2023/01/17 at 6:07 PM, Alex said: Basically a busbar is a copper plate. You connect all + terminals to one copper plate and all the - terminals to another copper plate. Then from there you take a cable to the inverter. Here is an example of one: Solarwize 1000A Bus Bar Combiner Box 10P Thanks. There was a DIY done by a forum member that I saw, but can't find the post.
January 19, 20233 yr 17 minutes ago, swazz99jhb said: Thanks. There was a DIY done by a forum member that I saw, but can't find the post. I remember seen one where he used plumbing copper pipe.
