Inverter and battery choice
Hi everyone. First time posting here and I’m with very little understanding of this side of things so please explain like you would do to a novice.
I have an option of 2x 5.12v batteries, 12 panels connected to an 8kw inverter or 2x 5kw inverters. I want to use Solar during the day and battery storage at night. Should I go for rhe 8kw or the 2x 5kw inverters? I consume an average of 40kwh per day and can run the big loads during the day. Another option could be to have 3 batteries with the 8kw inverter.
on the 2x 5kw inverters wil they work as independent inverters each running it’s battery or the 2 should be connected to talk to each other and be one bigger system?
I’ll appreciate your guidance.
If you get the 1 8kw you will be limited to 2 mppts whereas having 2 5kw inverters you double the mppts to 4. The 2x5kw also give some redundancy / resilience if 1 inverter packs up - all be it at 50%. The 2x5kw will work as 1 systems as the inverters are installed in parallel
Some questions to help you:
  • Do you regularly use more than 8kw of appliances at a time (this helps with 8kw vs 10kw)
  • How much electricity do you use between 4pm and 7am (this will help with battery sizing)
  • How much of that 40kwh usage can be moved to daytime hours?
  • How much roof space do you have (theoretical max number of panels) >> number of mppts
Thanks Mzezman
I have not done an analysis to answer some of your questions  but let me try it this way:
1. I may have short bursts where the kettle is boiling, microwave is on and the oven is on when my wife is doing her thing in the kitchen
2. And he biggest consumer between 4pm and 7am is the geyser and sometimes the oven
3. I can program the geyser to take most of my he load during the day
4. I have ample roof space  north facing I can do 9 panels. East facing I can do 7 and west facing maybe 7 there too
Edited by TimbaLand
39 minutes ago, TimbaLand said:
Thanks Mzezman
I have not done an analysis to answer some of your woes tika but let me try it this way:
If you can shift your geyser to mainly charge during the day using the PV then you'll hopefully reduce or even eliminate the need to have it run overnight
Oven can also be run during the day on PV- the nighttime usage might be an issue with 2 batteries though - remember you always want to have a % in the batteries in the case of a midnight loadshed or fault. There ARE ways you can schedule things and switch them on / off smartly depending on your inverter and general IOT skills. You could also set the time the oven is on to be drawn from ESKOM, e.g. have the house run on Eskom from 5-6pm and use the oven then?
On 2023/03/05 at 3:26 PM, TimbaLand said:
Thanks for the guidance
Not sure if you have made up your mind, you also did not say which inverter you are considering, but on the Deye and Sunsynk Inverters you will mostly be limited to the 460w panels due to the 13amp limit on the MPPT on the 5kw models.
I have 540 watt ja solar mono panels and they run perfectly fine. 4 in series on one mppt and 6 in series on the second mppt.
No clipping at all and on good days if I have enough load I get over 500 watts per panel continuously.
I have had on some occasions with scattered clouds and diffusion, panels peaking of over 570 watts per panel.
Edited by WannabeSolarSparky
This is more of an issue with the Canadian panels as they are much more amp heavy than JA panels.. the 550w Canadians will regularly do 13-17A.
  • 1 year later...
You said your daily usage is an average of 40kw a day and you want to go of grid .
12 panels and 8+ kw inverter should work but 2 battery on electric stove and geyser I don't think is going to be enough you will have to look more at 20kw battery's and still charge geyers mostly through the day .
Let me give you better idea .
Before I built my system my average consumption was average 17kwh per day that's more than  half yours  .
I have 4.4kw solar ,5.5 kw inverter and 10kw battery have stove and gas water warmer for cooking and  showering or bathing we 2 to 3 in the house with only 1 fridge .
From around 18:00-22:30 is the main load on batterys  of average of 500w.  By the morning my batterys are 65% if the wife uses the gas for cooking but if she uses the micro for  30 to 45 minutes the next morning battery's are 55% this is now in winter summer the days will be longer .
My loads are very low yet we use around  4000 kw from the batterys so if you planing on charging geysers and loads are double my loads at peak times in the evening you going have to budget on at lead 3 to 4 battery's as it's not healthy for lithium to be discharged daily to around 30% .
