Seplos BMS v2 10E is amazing.
Hi @Chris_S 5Kw SunSynk. I have a downloaded manual but don't seem to find the pinouts. I might have downloaded the wrong version? This is what I found for the BMS side picture below.
For the inverter I found a Segen Solar training manual
CAN Pin 1: CAN-H
         Pin 5: CAN-L
         Pin 8: GND
Edited by Greglsh
Has anybody got a SunSynk inverter connected to a DIY battery, on the SunSynk registration page they ask for the serial number of the battery. What do I put there as I don't have a serial number?
You mean bms connected to inverter?
CAN Pin 1: CAN-H
         Pin 5: CAN-L
         Pin 8: GND
I'm not sure about the 5kw my 8kw just used a normal network patch cable.
12 minutes ago, Greglsh said:
@Chris_S please could you send me your Seplos V2 10E parameter file, I would like to try it and see.
I'll do so tomorrow morning. It's on spare laptop with no email on it. I'll transfer the file and send to you.
Not much was changed only 4-5 voltage settings. Stock parameters are fine until tomorrow.
Sorry to hassle you @Chris_S just a reminder for your battery parameter file just so I can see what changes you made.
Still don't know what I should put for a serial number for the DIY battery when I register the SunSynk inverter online, has anybody else done this and what serial number did you use?
Why don't you just put the serial number of the BMS? My v3 has a serial number on the unit and it shows it on the pc software
