June 10, 201511 yr Hi guys Anyone have any experience with the above. I know renesolar known for their panels, not sure if their inverters are any good. Considering the following: http://www.renesola.com/renesola-tl-5kw-230v-50-60hz-grid-tied-solar-inverter-2-mppt5-year-dc-switch-wi-fi-cardweb-monitor-china-7442/ How does this compare with the infinisolar 3/5kw plus? I know it has wifi but not sure what the benefit of DC switch is? Does this unit allow the same switch over between grid and solar as the infinisolar? Thanks in advance Haggers
June 15, 201511 yr Author http://www.mppsolar.com/v3/mpi-hybrid-series-2/ And these perhaps? Output up to 5.1kw ...
June 16, 201511 yr you will find on their hybrid , it is actually a rebranded Goodwe. I think the grid tied units are also, as goodwe is the only one with ezmonitor,etc
June 16, 201511 yr Author Hi Mike, are you sure? The hybrid in the link has very similar specs to the infinisolar 3kw plus ... main difference as is higher input and outputs ... up to 6kw with some sort of grid relay? Are you perhaps talking about another model? Cost is 16k excluding import taxes etc
June 17, 201511 yr http://www.mppsolar.com/v3/mpi-hybrid-series-2/ And these perhaps? Output up to 5.1kw ... These are infinis.
June 18, 201511 yr Author Hi, most prob then an OEM plus model of the infini but seems like one on steroids as the grid relay added allows additional output. Spoke to salesmen from Mpp solar. Looks like landed cost of about R18k ... anyone install this or local supplier?
September 22, 201510 yr Hi, most prob then an OEM plus model of the infini but seems like one on steroids as the grid relay added allows additional output. Spoke to salesmen from Mpp solar. Looks like landed cost of about R18k ... anyone install this or local supplier? Is that price including import duties?
