PHORAM is coming...
Hello everyone.
I wanted to show you the software that I have been working on for about 7 months in my few spare time.
I called it PHORAM, acronym for: PHOTOVOLTAIC RELAY APPLICATION AND SOLAR MONITOR
Of course I am already using it in my solar installation and I plan to share it with all of you as soon as possible, completely free of charge for Power Forum members and all those who subscribe.
These are just some of the screens to give an idea of what the system does. Then I show some other screens. This is just an introduction.
For now, it will only be available for all the most modern current inverters of the hybrid type MPPSolar, Infini Solar, Voltronic and all those whose return of the QPIGS command coincides with this protocol:
https://www.google.com.ar/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiVm_rk6JvaAhUGipAKHW-2AocQFggpMAA&url=https%3A%2F%2Fwww.photovoltaikforum.com%2Fdownload% 2Ffile.php% 3Fid% 3D41146 & usg = AOvVaw1pEk0gAIpaG3RYbttEY_US
Once I finish correcting some errors and finish translating it into English I will put it for download. I intend for the system to grow with a large number of features. The system is bilingual Spanish / English.
Here are some screens:
@Sidewinder
I'm sorry but my inverter model does not support parallel work, so I could not prove anything unfortunately. There will not be two versions. There will be a bilingual one with selection from the Menu.
I think it works perfectly with the 3KW, 5KW and 10KW Hybrid models of InfiniSolar and obviously 5.5 KW, for now, I'll see later if with some restrictions on the amount of information I can adapt it (when I finish all the updates I want to add) to the models OFF GRID that work with the most known RS232 protocol and investigated in most forums.
Some problem with the Link that I copied and pasted before.
The communication protocol is found in Google, writing the following terms:
