JohanBeukes Posted May 7, 2023 Share Posted May 7, 2023 I bought a fivestar 5kw inverter VL-5048P-FS and a fivestar 7.68kw lithium iron battery FS-D01-48150. How do I connect the inverter to the battery for comms? There are no instruction with regard comms in the manuals and the inverter only has a RS232 connection and a USB connection. Another thing which I found to be strange is although it is a 48v inverter all programing settings on the inverter are 12v. Can any body please assist (not very clever with these kind of things) Quote Link to comment Share on other sites More sharing options...
McGuywer Posted May 8, 2023 Share Posted May 8, 2023 On 2023/05/07 at 4:12 PM, JohanBeukes said: I bought a fivestar 5kw inverter VL-5048P-FS and a fivestar 7.68kw lithium iron battery FS-D01-48150. How do I connect the inverter to the battery for comms? There are no instruction with regard comms in the manuals and the inverter only has a RS232 connection and a USB connection. Another thing which I found to be strange is although it is a 48v inverter all programing settings on the inverter are 12v. Can any body please assist (not very clever with these kind of things) Not sure if this is the same inverter but look from page 12: https://voltaconsolar.com/DOWNLOAD-FILES/VOLTASOL-Plus-5KW-manual-20160907.pdf Quote Link to comment Share on other sites More sharing options...
JaVH Posted January 19 Share Posted January 19 Hi, please can I ask if you tested or opened the cover of this battery? I also bought a fivestar 7.65kw battery (150ah) but inside is 92ah cells. The shop were I bought it is criminals and does not want to help me. I just ask to find out if its the make, fivestar, or that shop only. Regards Quote Link to comment Share on other sites More sharing options...
madness_za Posted January 19 Share Posted January 19 1 hour ago, JaVH said: Hi, please can I ask if you tested or opened the cover of this battery? I also bought a fivestar 7.65kw battery (150ah) but inside is 92ah cells. The shop were I bought it is criminals and does not want to help me. I just ask to find out if its the make, fivestar, or that shop only. Regards Fivestar has little to no credibility. No support for them locally. Quote Link to comment Share on other sites More sharing options...
TaliaB Posted January 20 Share Posted January 20 12 hours ago, madness_za said: Fivestar has little to no credibility. No support for them locally. I tried diffrent communications Rs232 and Usb the Fivestar inverters can not communicate not with their own make battery and not with Solar Assistant they are to me dumb inverters do not know what or how you can establish comms with these inverters so if someone was successful to establish communications please let us know how to. Quote Link to comment Share on other sites More sharing options...
