RuanLaubscher Posted May 29, 2023 Share Posted May 29, 2023 Good day guys, I need some advice and assistance on the following. I have a little confusion over the grid input/output on the inverter. My total Home Load is about 15KW at max I am looking to connect only essentials(1KW max) on the Load output of the inverter in order to battle loadshedding right. The rest of the load will stay on the mains , but id like to supplement the mains via the PV to lower electricity costs. Should this load exceed 12KW , would the rest of the load be supplied via the mains like in a typical gridtie application? Without tripping the inverter Thanks in advance. Quote Link to comment Share on other sites More sharing options...
RuanLaubscher Posted May 30, 2023 Author Share Posted May 30, 2023 On 2023/05/29 at 2:43 PM, RuanLaubscher said: Good day guys, I need some advice and assistance on the following. I have a little confusion over the grid input/output on the inverter. My total Home Load is about 15KW at max I am looking to connect only essentials(1KW max) on the Load output of the inverter in order to battle loadshedding right. The rest of the load will stay on the mains , but id like to supplement the mains via the PV to lower electricity costs. Should this load exceed 12KW , would the rest of the load be supplied via the mains like in a typical gridtie application? Without tripping the inverter Thanks in advance. I am not referring to the aux output. If anyone could assist that would be great Quote Link to comment Share on other sites More sharing options...
abd7 Posted May 30, 2023 Share Posted May 30, 2023 They 12kw rating is for essentials ie things connected behind the inverter, which will be powered up even when there is no grid. There's no limit on the non essentials ie those things not connected through the inverter. The limit will be the municipal supply / meter. So if you only want 1kw essentials to be supplied during loadshedding there's no reason to go with a 12kw machine. Quote Link to comment Share on other sites More sharing options...
FixAMess Posted May 31, 2023 Share Posted May 31, 2023 Is your home running on 3 phase power, as above, if you only have 1kW on essentials you dont need a large capacity, 3 phase inverter. Quote Link to comment Share on other sites More sharing options...
ZaydS Posted May 31, 2023 Share Posted May 31, 2023 He could put more circuits on essentials/inverter? Quote Link to comment Share on other sites More sharing options...
P1000 Posted May 31, 2023 Share Posted May 31, 2023 On 2023/05/29 at 2:43 PM, RuanLaubscher said: would the rest of the load be supplied via the mains like in a typical gridtie application? Exactly like a grid-tie, yes. RuanLaubscher 1 Quote Link to comment Share on other sites More sharing options...
RuanLaubscher Posted May 31, 2023 Author Share Posted May 31, 2023 20 hours ago, abd7 said: They 12kw rating is for essentials ie things connected behind the inverter, which will be powered up even when there is no grid. There's no limit on the non essentials ie those things not connected through the inverter. The limit will be the municipal supply / meter. So if you only want 1kw essentials to be supplied during loadshedding there's no reason to go with a 12kw machine. Perfect thanks Quote Link to comment Share on other sites More sharing options...
RuanLaubscher Posted May 31, 2023 Author Share Posted May 31, 2023 12 hours ago, FixAMess said: Is your home running on 3 phase power, as above, if you only have 1kW on essentials you dont need a large capacity, 3 phase inverter. 20 hours ago, abd7 said: They 12kw rating is for essentials ie things connected behind the inverter, which will be powered up even when there is no grid. There's no limit on the non essentials ie those things not connected through the inverter. The limit will be the municipal supply / meter. So if you only want 1kw essentials to be supplied during loadshedding there's no reason to go with a 12kw machine. Thanks for the help Yes my house have a 3phase supply . The reason for the 12kw inverter is i want to use as little as possible power from the grid during the day when pool pump, washing machine etc etc are running and eventually in the future to go “off grid”. Once the system is up and running ill do my changes on the essential side Quote Link to comment Share on other sites More sharing options...
