Axpert VMII 57 Fault and 09 Fault Repair Help Needed
7 hours ago, wael_fathe said:
sako inverter manual refers mysteriously that drive of dc to ac is the cause of 08.....how that can be is beyond my brain
The inverter needs to do a quite delicate dance to keep the bus voltage within bounds while also charging the battery while loads and solar conditions are varying randomly. So I'm not surprised that a fault with the DC->AC or the DC-DC, including both their gate drivers, could cause fault code 08 (bus voltage too high).
  • Replies 75
  • Views 19.1k
  • tanveerhabib
    tanveerhabib
    Hello, I have gone through this manual which you have shared and the inverter which I am repairing is exactly the same, I am attaching an image from the same tutorial, and I have marked a part which i
  • BritishRacingGreen
    BritishRacingGreen
    Below is a trace for a MAX7.2 (OG7.2) , your machine will have the same circuit , and you may even have the same component enumeration , but please check against your board , especially if you decide
  • tanveerhabib
    tanveerhabib
    In the above manual there is one 100 ohm resistors before zd 12 and zd6 and there is another 100 ohm resistor before zd 20 and zd 21 but the schematic which you shared here https://forums.aeva.asn.au/
