Charge cycle of Hubble AM-5 using Sunsynk 5 kW
Hi all,
My Sunsynk shows that the AM-5 constantly draws ~1 A (~50 W) even after it is supposedly fully charged. I'm under the impression that the charge cycle for these LiFePO4 batteries should go from constant current, to constant voltage, and then the current flow should stop until a top up is required. However, it seems that I never reach this last phase... Is this normal behavior or have I perhaps entered the wrong battery charge parameters?
I only have one battery and no PV.
7 minutes ago, Dazzard said:
The electronics on the battery itself also needs power to run. The 50W seems a bit high, mine uses around 20W. The Sunsynk style inverters do lie a bit about the wattages they see on different inputs and outputs, so yes, the 50W sounds in the ballpark.
Edited by HendrikBigChief
Even the flow graph doesn’t seem to make sense. I should be pulling 248 W from the grid? So the consensus is that the inverter does not correctly measure how much power the battery is pulling? Can I trust the load measurements?
Edited by Dazzard
Next to Power Flow at the top, Sunsynk should put in brakets: (LIES)
When my inverter says 0 from grid, it is actually pulling 180W, that is how badly it lies.
How did you measure your 180W?
15 minutes ago, HendrikBigChief said:
I have an external probe as part of an effergy engage.
Efergy does not measure watts, it measures apparent power. Your inverter may only generate unity power factor when grid connected, so unless you only have resistive loads, the efergy will measure something when the actual power is 0W.
The effergy 100% matches what my prepaid meter also says...
That is worrying. Your prepaid should be configured to only bill for real power (assuming you are a residential user). But it is definitely capable of measuring apparent power, and most of them can be configured to bill on either. With only a current clamp like the efergy, you cannot measure real power.
But as I said, when the inverter says 0 W from grid, the efergy picks up 180W. The 180W is what the Inverter itself uses. That 180W is not reactive power. There is no motor running, it is plainly the inverter. Everything else is switched off in my house.
That doesn't sound very scientific, the sunsynk itself is also not a resistive load. As much as I like bashing random brands, you are going to need stronger proof of what you are claiming.
Edited by P1000
We have raised the point that inverters do have a lot of reactive power due to all the inductors used at convertor stages.
I found these using a CT are quite accurate against my munic meter. Also a plus is even with a 20m distance to the CT. Mine is now in use for 5yrs.
For VA and PF one needs to calculate it.
I also like the 3 digit display for accumulated power used and easy to reset to zero.
Do you work for Sunsynk/Deye?
Surely, if the Inverter reports 0W from grid, but my meter says 180W, then there is an issue. The inverter should measure actual power.
In my limited working with inverters they tend to measure the load power used which excludes own consumption.
This will vary from make to make. I measure own consumption as the difference between input and output. The same for the PV side
On my two 5 KVA 5000 ES Growatt inverters I can see a consumption of +_ 1.8 Amps. So 0.8 Amps per inverter. See attached dashboard. image.thumb.png.5cb53063116ec6e7ab90c809b384d9a6.png
Edited by Antonio de Sa
4 minutes ago, Antonio de Sa said:
On my two 5 KVA 5000 ES Growatt inverters I can see a consumption of +_ 1.8 Amps. So -8 Amps per inverter. See attached dashboard. image.thumb.png.5cb53063116ec6e7ab90c809b384d9a6.png
8A per inverter but 1.8A for both?
We have already established that your meter does not measure what you think it measures...
And no, I don't even own a Sunsynk.
Sorry could not see the values on a small screen.
