Sunsynk / BSL Combo
Sunsynk 8kw with 2 x 5.1 BSL Powerline 5 and 14 x 550w panels. 7 east and 7 west.
Hi, how do these slimlines compare to the 7kw bsl mounrack ito comparable cycles?
Hi. 8000 cycles on the slimline vs 4000 cycles on the rack mount at 80% DOD
Hi Leshen
I am very keen on the BSL battery brand and I think you have been installing a few of them with the SunSynk inverters . I wanted to ask your opinion on them any problems you have had. I have Solar Assistant and wanted to know if this will work with the BSL Powerline 5 batteries.
Hi Leshen
No problems in 3 years. I have them at my own home. See pic
That cabinet is it specific for batteries or is it a "normal" IT/Server 19 inch rack mount cabinet? 35Kwh of battery very nice.
From the few rack mounted batteries I have seen they were all based on a 19 inch rack as has been used in the electrical and IT field from around 1980 when I 1st used it for modular equipment.
Just to add the height is measured in a U unit.
Thanks Scorp007 , I thought maybe these cabinets might have a busbar system so might be battery specific??
What is mounted inside can be custom made. For general electrical work where one would have a whole row of 2.4m high panels the standard design had a earth bar at the bottom so that the whole row is earthed from cubicle to cubicle. This was a solid copper bar with threaded holes for connections.
One with side door and the front against the wall. Back cover removed.
