Mecer inverter
My mecer inverter is not connected to utility power. The inverter only comes on when the fridge is switched on, if I turn off the fridge, the lights for the house start flickering on and off. What could be the cause?
EDIT(ive added a screenshot of the setting)
also known as power sensing. if the current draw is very low, the inverter swithces off
what mecer model is it? and there is a "power saving" setting that you need to disable.
check the manual. im not 100% sure what is is called.
Power saving.
Standby.
or something like that
Edited by Flouw
added screenshot
