RCA <-> Co-axial adaptor
I have two male cable ends, one RCA, the other co-axial that I need to . Is there a vendor that supplies a female coupler, or should I make up a cable, and if so, is it a simple inside-inside, outside-outside connection?
Thanks!
Yes, but what is this for? the TV Co-ax connector, presumably is on RG59 or similar coax and the RCA, heck usually on audio cable/thin coax.. either way, you will have to make up a linking cable, I have never seen an adapter for those tow different use plugs top be able to join.
thanks. It's actually for a depth sounder transducer on a sailboat. Existing through-hull transducer (RCA) instrument is damaged beyond repair. Alternate display unit uses co-axial, but transducer is mounted inboard and thus less reliable. I want to connect the RCA cabled transducer to the co-axial device. Figured it was a bit complicated to explain the context in the original post 😉
Edited by Chad
