Connect Home Assistant with Sunsynk
  • Replies 99
  • Views 27.1k
  • MartinViljoen
    MartinViljoen
    I made a major change to this add-on which resulted to a change in the entity names. Therefore I copied it over to a new repository and versioned it v2. The new version supports multiple inverters.
  • MartinViljoen
    MartinViljoen
    Update 2.1.8 now available. https://github.com/martinville/solarsynkv2 This update lets you send  inverter settings back to your inverter via HA -> SunsynkCloud -> Your inverter If you st
  • Giving it a go quickly. Worked well and recommend for someone not wanting to go through the whole node red process.
On 2024/12/04 at 11:59 AM, mkotschan said:
Good day
It is possible to add more than 1 inverter to the SolarSynk as i have multiple inverters i am needing to add to a dashboard?
Regards
Marcus
Yes ,just put multiple serial numbers in the serial field separating them with a semicolon ; I.E 12345;54321
Hello,
i hope everyone is well and if you had a break, that it was a great one.
i am a noob with HAS, and finding my way around - and am very happy so far with it all.
i have installed both the SolarSynk part from @MartinViljoen as indicated in the begining of this topic, as well as the the part from @slipx.
Thank you for great work.
i followed the installation instructions from the GitHub pages, and i have the SolarSynk entities and can see the populated with values. so far so good.
when i am trying to build a card like @MartinViljoen showed using @slipx, i get an error.
what i did was go to my dashboard, click on the edit button on the top right, and then clicked on Add Card.
when i try to build the custom card at the begining of this topic, using:
type: custom:sunsynk-power-flow-card
i get an error message of: Custom element doesn't exist: sunsynk-power-flow-card.
please can you guide me as to what i am doing wrong?
regards
Marc
10 minutes ago, vdpollm said:
Hello,
regards
Marc
i just removed it, rebooted and started over, and it works. thank you @slipx and @MartinViljoen for your great work
Hi,
I think there has been a regression with the latest update.
My battery SOC is often reporting as 0
I've disabled my battery full notification for now :)
Hi All
Has something changed recently ? I have redone my HA instance on new hardware and now I am getting this in the logs
/run.sh: line 545: [: ==: unary operator expected
Its also not detecting my inverters anymore
Inverter Information
Brand: null
Status: null
Max Watts: null
Plant ID: null
Plant Name: null
Inverter S/N: null
Hi All
Since the last Sunsynk cloud outage last week, the SolarSynk app returns all values as zeroes randomly on the curl fetch.
In the last 30min(6 rotations of the script) 4 x it returned values, 2 x it returned all zeroes.
Anyone else seeing this behavior ?
18 hours ago, DoubleP said:
Hi All
It should be fixed now in the new update, the sunsynk server issues is still causing the auth token to not be handed out reliably.
But to fix this I added a check in place for the script to keep retrying until the server gives a valid token.
Hi All
why not get your data direct from the inverter?
Thanks for the response, I have only had my solar for about 6 months, so still a noob with all this stuff, but I am learning as I go along :). I have been doing some reading up on getting the data directly from the inverter rather than the cloud.
Firstly thank you - I now have the invert information in Home Assistant.
Did you ever find a way to update settings that was compliant with the length of a helper?
I have tried a few things below all with error 500 - the inverter serial has been edited.
If there are a set number of parameters  that needs to be sent do you know the minimum set ? If the minimum set exceeds the HA text limit did you fine a work around ?
I just need to decide if I top up batteries on a cheap tariff on Time period 3 and 5 or not. So I would be ether setting those parameters to charge or not based on the battery state of charge. So enable Time 2 and Change the SOC2 to 100 to charge or Disable Time 2 and set SOC2 to 10 to continue discharge
Thank you
Updating Helper: input_text.solarsynk_x_inverter_settings with:  "cap1": "80",     "cap2": "80",     "cap3": "80",     "cap4": "80",     "cap5": "80",     "cap6": "80"
  "code": 500,
  "msg": "Internal Server Error",
  "data": null,
  "success": false
Clearing previously set temporary settings.
Fetch complete for inverter: x
Updating Helper: input_text.solarsynk_x_inverter_settings with: "genTime1on": false,     "time1on": true,
  "code": 500,
  "data": null,
  "success": false
Noob question and help needed or just comments to read a specific post further would help.
So I added the add-on. Verbose logging enabled. I can see the information returned in the logs from the inverter:
Please wait while curl is fetching input, grid, load, battery & output data...
Brand: Deye
Status: Normal
Max Watts: 8000
Plant ID: <plantID>
Plant Name: <plantName>
Inverter S/N: <Serial>
Data fetched for serial <Serial>. Enable verbose logging to see more information.
If ALL values are NULL then something went wrong.
battery_capacity 420.0
battery_chargevolt 53.8
battery_current -45.87
battery_dischargevolt 0.0
battery_power -2287
battery_soc 54.0
battery_temperature 28.6
battery_type 1
battery_voltage 49.9
day_battery_charge 3.0
day_battery_discharge 1.0
battery1_voltage 0.0
battery1_current 0.0
battery1_power 0.0
battery1_soc 0.0
battery1_temperature 0.0
battery1_status 1
battery2_voltage 0
battery2_current 0
battery_dischargevolt2 0
battery2_power 0
battery2_soc 0
battery2_temperature 0
battery2_status 0
day_grid_export 0.0
day_grid_import 6.9
day_load_energy 8.40
day_pv_energy 5.20
grid_connected_status 1
grid_frequency 49.86
grid_power 20
grid_voltage 238.1
grid_current 1.1
grid_power1 0
grid_voltage1 0
grid_current1 0
grid_power2 0
grid_voltage2 0
grid_current2 0
inverter_frequency 49.9
inverter_power 1147
inverter_current 4.8
inverter_voltage 239.2
inverter_power1 0
inverter_voltage1 0
inverter_current1 0
inverter_power2 0
inverter_voltage2 0
inverter_current2 0
load_frequency 49.86
load_current 0.0
load_power 1151
load_voltage 238.4
load_current1 0.0
load_power1 1151
load_voltage1 238.4
load_current2 0.0
load_power2 1151
load_voltage2 238.4
load_totalpower 1151
load_upsPowerL1 0.0
load_upsPowerL2 0.0
load_upsPowerL3 0.0
load_upsPowerTotal 1151.0
pv1_current 7.8
pv1_power 1801.0
pv1_voltage 233.3
pv2_current 7.8
pv2_power 1770.0
pv2_voltage 230.4
pv3_current 0
pv3_power 0
pv3_voltage 0
pv4_current 0
pv4_power 0
pv4_voltage 0
overall_state Normal
prog1_time: 00:00
prog2_time: 05:00
prog3_time: 09:00
prog4_time: 13:00
prog5_time: 17:00
prog6_time: 21:00
prog1_charge: false
prog2_charge: false
prog3_charge: false
prog4_charge: false
prog5_charge: false
prog6_charge: false
prog1_capacity: 40
prog2_capacity: 35
prog3_capacity: 40
prog4_capacity: 60
prog5_capacity: 60
prog6_capacity: 45
battery_shutdown_cap: 20
use_timer: 1
priority_load: 1
dc_temp: 48.7
ac_temp: 44.4
Attempting to update the following sensor entities
Sending to http://http://<ip>:8123
Reading settings entity -> solarsynk_<Serial>_inverter_settings
/run.sh: line 560: [: ==: unary operator expected
Helper entity input_text.solarsynk_<Serial>_inverter_settings has no value. Therefore no inverter setting will be sent for change.
Fetch complete for inverter: <Serial>
Fetching data for serial: <Serial>
Cleaning up old data.
Brand: Deye
Status: Normal
Max Watts: 8000
Plant ID: <plantID>
battery_chargevolt 0.0
battery_current -18.5
battery_power -919
battery_soc 53.0
battery_temperature -100.0
battery_type 1
battery_voltage 49.7
day_battery_charge 0.8
day_battery_discharge 1.3
battery1_power 0.0
battery1_soc 0.0
battery1_status 1
battery2_voltage 0
battery2_current 0
battery2_power 0
battery2_soc 0
battery2_status 0
day_grid_export 0.0
day_grid_import 5.2
day_load_energy 8.30
day_pv_energy 2.40
grid_connected_status 0
grid_frequency 49.96
grid_power 0
grid_voltage 239.6
grid_current 1.7
grid_power1 0
grid_voltage1 0
grid_current1 0
grid_power2 0
grid_voltage2 0
grid_current2 0
inverter_power 1159
inverter_voltage 240.8
inverter_power1 0
inverter_voltage1 0
inverter_current1 0
inverter_power2 0
inverter_voltage2 0
inverter_current2 0
load_frequency 49.96
load_current 0.0
load_power 1183
load_voltage 239.8
load_current1 0.0
load_power1 1183
load_voltage1 239.8
load_current2 0.0
load_power2 1183
load_voltage2 239.8
load_totalpower 1183
load_upsPowerL1 0.0
load_upsPowerL2 0.0
load_upsPowerL3 0.0
load_upsPowerTotal 1183.0
pv1_current 9.1
pv1_power 2208.0
pv1_voltage 245.8
pv2_current 0.0
pv2_power 0.0
pv2_voltage 2.3
pv3_current 0
pv3_power 0
pv3_voltage 0
pv4_current 0
pv4_power 0
pv4_voltage 0
prog1_time: 00:00
prog2_time: 05:00
prog3_time: 09:00
prog4_time: 13:00
prog5_time: 17:00
prog6_time: 21:00
prog1_charge: false
prog2_charge: false
prog3_charge: false
prog4_charge: false
prog5_charge: false
prog6_charge: false
prog1_capacity: 40
prog2_capacity: 35
prog3_capacity: 40
prog4_capacity: 60
prog5_capacity: 60
prog6_capacity: 45
use_timer: 1
priority_load: 1
dc_temp: 47.0
ac_temp: 43.2
All Done! Waiting  300  sesonds to rinse and repeat.
So it seems to CURL correct and everything is good.
Questions:
1. Do I need to configure something in the /homeassistant/configuration.yaml to be able to use any of these values?
2. Do I now add a powerFlow card like: Slipx Power Flow Cards ?
I followed the Node-red and slipx but I could not get my two inverters working. Stumbled across the above implementation and just like to get an overall plain look at what my house uses and plot graphs.
Having installed this yesterday
1. Just look in entities and you will find them all. You don't need to do anything.
2 there is no need to install the card but it does look nice.
my issue is writing changes to the system which I think it a little picky ( the Sunsynk end ) and hopefully someone will share their method
Hi JeremyLondon,
So to understand you correct, I can then just check under: Settings,Devices & services, Enttities. There I find all the values and some that are unavailable.
So follow up question:
1. How would I now get a nice flow chart or something similar to what Slipx has? Cause from first post in this discussion I thought I would just be able to change the name of the sensor but what I can see there is no sensor if its not configured in the configurations. So should I then add stuff in my configuration.yaml?
I'm not 100% sure what you mean.
Are you having problems installing the SlipX card via HACS ?
You dont have to fiddle with the configuration.yaml The SolarSynk Addon will send which ever values it found to a predefined entity. The naming convention is
Example
sensor.solarsynk_[INVERTERSERIAL]_battery_power1
You cannot rename them, unless you clone the repository and edit the run.sh file. But I dont see any reason to do that.
The SlipX card and the SolarSynkv2 Addon are totally 2 different developments and are not directly related in any way.
SolarSynk Addon - Fetches information from your Sunsynk Cloud Account and then populates entities with values. Doesnt do anything else.
SlipX Card  - Is used to graphically display the entity information on a nice looking card on your HA dashboard.
You dont have to use the slipX card there are some of the boring default HA cards you can also use.
Hi Martin,
Thank you for the post.
I gathered about the SolarSynk Addon that pulls information and stores it in entities and I can have a look at them there. What I am after now is to get a display like SlipX cards. From reading your post it sounds as easy as changing the name of the entity but the part I do not understand is the current SlipX flow works with Sensors setup in the configuration.yml.
So I was hoping of getting a simple example of how one has setup a graphical view of the solar. Surely one do not go into settings, devices and services and then entities OR go to history and view entities.
I think I know what you mean now. Since the original post further developments were made.
On the SlipX card there is now a GUI, all you do go to each datapoint and search for the entity you want in order to link it.
You can also offcoarse opt to manually edit the SlipX configuration yaml file if you wanted to. (Not to be confused with Home assistant's configuration file)
I.E
What I meant in the first post was I named the entities to be similar to the slipx card (On a developer level) so its easy to map them. As a user you cannot change them. The naming of both addon and card also later changed slightly so its not relevant anymore.
Edited by MartinViljoen
@MartinViljoen, I am problaly doing something wrong or my HA is not setup correct.
See below the Entities under the template does not seem to be responsive. I cannot see any data but If I pull the logs from the add-on it has all the correct data with the current date and time so it was just pulled.
-- SolarSynk - Log
Script execution date & time: 11/02/2025 11:17:50
Verbose logging is set to: true
HTTP Connect type: http
Getting bearer token from solar service provider's API.
Valid token retrieved.
Bearer Token length: 646
Sunsynk Server API Token: Hidden for security reasons
Refresh rate set to: 300 seconds.
Note: Setting the refresh rate of this addon to be lower than the update rate of the SunSynk server will not increase the actual update rate.
Fetching data for serial: <>
Brand: Deye
Status: Normal
Max Watts: 8000
Plant ID: <>
Plant Name: DirkjLouw
Inverter S/N: <>
Data fetched for serial <>. Enable verbose logging to see more information.
battery_current -21.22
battery_power -1147
battery_soc 99.0
battery_temperature 30.7
battery_type 1
battery_voltage 54.1
day_battery_charge 9.4
day_battery_discharge 0.5
battery1_power 0.0
battery1_soc 0.0
battery1_status 1
battery2_voltage 0
battery2_current 0
battery2_power 0
battery2_soc 0
battery2_status 0
day_grid_export 0.0
day_grid_import 6.3
day_load_energy 8.60
day_pv_energy 13.70
grid_frequency 50.0
grid_power 0
grid_voltage 238.4
grid_current 1.5
grid_power1 0
grid_voltage1 0
grid_current1 0
grid_power2 0
grid_voltage2 0
grid_current2 0
inverter_frequency 50.0
inverter_power 1063
inverter_current 4.5
inverter_voltage 239.4
inverter_power1 0
inverter_voltage1 0
inverter_current1 0
inverter_power2 0
inverter_voltage2 0
inverter_current2 0
load_frequency 50.0
load_current 0.0
load_power 1105
load_voltage 239.0
load_current1 0.0
load_power1 1105
load_voltage1 239.0
load_current2 0.0
load_power2 1105
load_voltage2 239.0
load_totalpower 1105
load_upsPowerL1 0.0
load_upsPowerL2 0.0
load_upsPowerL3 0.0
load_upsPowerTotal 1105.0
pv1_current 4.6
pv1_power 1165.0
pv1_voltage 253.0
pv2_current 4.6
pv2_power 1163.0
pv2_voltage 253.4
pv3_current 0
pv3_power 0
pv3_voltage 0
pv4_current 0
pv4_power 0
pv4_voltage 0
prog1_time: 00:00
prog2_time: 05:00
prog3_time: 09:00
prog4_time: 13:00
prog5_time: 17:00
prog6_time: 21:00
prog1_charge: false
prog2_charge: false
prog3_charge: false
prog4_charge: false
prog5_charge: false
prog6_charge: false
prog1_capacity: 40
prog2_capacity: 35
prog3_capacity: 40
prog4_capacity: 50
prog5_capacity: 50
prog6_capacity: 40
use_timer: 1
priority_load: 1
dc_temp: 50.4
ac_temp: 48.7
Sending to http://http://192.168.0.87:8123
Reading settings entity -> solarsynk_<>_inverter_settings
Helper entity input_text.solarsynk_<>_inverter_settings has no value. Therefore no inverter setting will be sent for change.
Fetch complete for inverter: <>
Brand: Deye
Status: Normal
Max Watts: 8000
Plant ID: <>
Inverter S/N: <>
battery_current -1.2
battery_power -64
battery_soc 98.0
battery_type 1
battery_voltage 53.9
day_battery_charge 4.0
day_battery_discharge 0.9
battery1_power 0.0
battery1_soc 0.0
battery1_status 1
battery2_voltage 0
battery2_current 0
battery2_power 0
battery2_soc 0
battery2_status 0
day_grid_export 0.0
day_grid_import 5.0
day_load_energy 8.70
day_pv_energy 6.30
grid_frequency 50.2
grid_power 28
grid_voltage 240.0
grid_current 1.7
grid_power1 0
grid_voltage1 0
grid_current1 0
grid_power2 0
grid_voltage2 0
grid_current2 0
inverter_frequency 50.2
inverter_power 1082
inverter_current 4.6
inverter_voltage 241.2
inverter_power1 0
inverter_voltage1 0
inverter_current1 0
inverter_power2 0
inverter_voltage2 0
inverter_current2 0
load_frequency 50.2
load_current 0.0
load_power 1103
load_voltage 240.5
load_current1 0.0
load_power1 1103
load_voltage1 240.5
load_current2 0.0
load_power2 1103
load_voltage2 240.5
load_totalpower 1103
load_upsPowerL1 0.0
load_upsPowerL2 0.0
load_upsPowerL3 0.0
load_upsPowerTotal 1103.0
pv1_current 5.1
pv1_power 1264.0
pv1_voltage 252.5
pv2_current 0.0
pv2_power 0.0
pv2_voltage 2.5
pv3_current 0
pv3_power 0
pv3_voltage 0
pv4_current 0
pv4_power 0
pv4_voltage 0
prog1_time: 00:00
prog2_time: 05:00
prog3_time: 09:00
prog4_time: 13:00
prog5_time: 17:00
prog6_time: 21:00
prog1_charge: false
prog2_charge: false
prog3_charge: false
prog4_charge: false
prog5_charge: false
prog6_charge: false
prog1_capacity: 40
prog2_capacity: 35
prog3_capacity: 40
prog4_capacity: 50
prog5_capacity: 50
prog6_capacity: 40
use_timer: 1
priority_load: 1
dc_temp: 52.0
ac_temp: 49.4
@MartinViljoen, in the logs I spotted:
Reading settings entity -> solarsynk_<inverterSN>_inverter_settings
What is the issue with the run.sh here?
Not quite sure. This is bash script and i dont have much error control in it so when ever there is an unexpected string or int encountered it will give this kind of error. But looking at your log I suspect you have a semicolon at the end of your inverter serilal numbers. I.E Serial1;Serial2; Serial1;Serial2  , So its parsing Serial1 Serial2 then a blank serial ?
Seeing there are many request for better error control , sending settings ect I decided to re-create the addon using python which will be much better. Its almost done i'm in the process of testing it and adding the ability to send settings then I will make it available. instead of
