Maximum battery discharging current
What values should be put in program 41 "Maximum battery discharging current" of the 10kw axpert max II inverter, connected to two pylontech Up5000 batteries?
1 hour ago, GMAC said:
Specs show an normal discharge of 2400w so making 50amps per lithium so max 100amps or 4800w if running in parallel
Is this not the same as 100A for 2 batteries as the OP asked? As per the reply from @Nexuss
Yip just in more detail . For most that have a good understand of what going on short and sweet is good but for new bees a  bit more detail helps .
