January 2, 20242 yr I have a strange issue, Kodak Axpert Max, 7.2KW (Kodak Max) - PV exist but inverter showing 0 on PV1 or PV2, no errors on the LCD. Has anyone experience the similar issue? Edited January 2, 20242 yr by Phakela typo
January 2, 20242 yr 3 minutes ago, Phakela said: I have a strange issue, Kodak Axpert Max, 7.2KW (Kodak Max) - PV exist but inverter showing 0 on PV1 or PV2, no errors on the LCD. Has anyone experience the similar issue? When you say 'exist' do mean the pv is present on the input terminals only, or do you mean that the inverter is actually using pv power but it is not on display? When you say '0' do you mean zero voltage or zero current or both?
