RCT Axpert 1000W 12v inverter no AC output during LS
Good day,
Our estate has a small RCT Axpert 1000W 12v inverter which is used for backup power for streetlights etc. (about 300W total load). It's connected to a Hubble S-100A battery.
It's been running perfectly fine since July 2023. However, the inverter is no longer supplying any output power during load-shedding. There is no alarm/fault code and the inverter display shows that the battery is full (13.7v), the grid input voltage is 0v, Output is 230V AC, and load is 0%.
A multimeter confirms 0V AC at the inverter's output connecter.
When grid returns, the AC on the inverter output is also back.
We have switched the inverter on/off - same behaviour. Also, changed from Apl to Ups - same behaviour.
Any thoughts, assistance will be much appreciated.
10 minutes ago, Mier said:
Good day,
Let's give @BritishRacingGreen time to share his specialist knowledge.
Strange to see it shows 230V output but nothing powering the load.
Yes. And stranger that bypass mode works. That suggests a fault with the inverter relay. I'm guessing that the 230V is a measurement of the inverter (DC -> AC converter) output, not the load voltage.
So sorry: it doesn't seem like anything simple.
