December 1, 20187 yr Good day guys Just a quick question, can I mix old and new Pylontech batteries. I have 3 which are a year old and I want to add 1 more due to the current load shedding we are having. Thanks
December 1, 20187 yr Author 6 minutes ago, Javi Martínez said: You won´t have any problem. Each module is protected. Thank you
December 7, 20187 yr Hi I have something similar - 2 "older" batteries" and a newer one. the FW versions differ so experiencing some issues. How do you update the firmware on the batteries? Sorry to hijack your thread 😏
December 11, 20187 yr On 2018/12/07 at 10:40 AM, Henkt said: How do you update the firmware on the batteries? I would speak to your supplier. Updating firmware can be traumatic and I know of an Aussie user that bricked his module. I have 4 batteries with 2 different firmwares. Yes there are some idiosyncrasies but essentially they work. It is not an arena I would rush into.
December 11, 20187 yr On 2018/12/02 at 4:13 PM, DaveSA said: What is the reason why the "older'" Axpert Inverters were not Lithium-Ion compatible ? Attached is the Leoch LFeLi spec sheet which claims it : "Can use most VRLA Chargers for this system" Many thanks LFeLi-4850C.pdf Possibly when the first Axpert came out, batteries like BYD and Pylontech weren't on the market yet.
