Question around Pi and the 12v Power supply
9 minutes ago, JacoG said:
I have 3 batteries in parallel, do I just connect the 12v power supply to the terminals of one battery?
https://solar-assistant.io/shop/products/dc_usb_psu
Yes but before you do that put a dc fuse(1~2A) in series with the pos lead cut the lead and put the fuse inbetween the cut wires.
Edited by TaliaB
8 minutes ago, JacoG said:
Thank you Talia, I was worried about just connecting straight to the battery, where did you buy that fuse Holder?
Don't know which province you situated but when i was still in Gauteng there is quite a few electrical outlets that sold them Bright Lighting is one of them they have the dc fuses as well.
https://britelighting.co.za/products/in-line-fuse-holder
Edited by TaliaB
Mmmm so I didnt do this, I just connected as is to each terminal...bad thing if its not connected via a fuse like this?
As the saying goes what can go wrong could go wrong. The chances are good the Pi will have an internal fuse don't really know as i haven't opened one up yet, but with batteries that can supply high currents in the event of short curcuits it is just good practice to install an external fuse.
