May 30, 20242 yr Hi all, I'm not using the Sunsynk App at all as I'm using an ESP32 with Home Assistant to control/monitor my inverter. With the server issues experienced by Sunsynk (again), I was wondering what impact there will be if I turn off the Time Sync on my Sunsynk Inverter. I keep losing data (I know 1st world problem) at least once a month so really trying to avoid this issue. Any input would be greatly appreciated 🙃 Edited May 30, 20242 yr by Muttley Added image
May 31, 20242 yr Slipx added some code a while back that will enable you to sync your inverter time with HA instead #Set the interval to sync your inverter time with HA or comment out to disable It will at the very least remove this ( proving to be ) unreliable variable. And you won't experience clock drift as a result of turning off completely. So all you need do is update your ESP code 10 hours ago, Muttley said: Hi all, I'm not using the Sunsynk App at all as I'm using an ESP32 with Home Assistant to control/monitor my inverter. With the server issues experienced by Sunsynk (again), I was wondering what impact there will be if I turn off the Time Sync on my Sunsynk Inverter. I keep losing data (I know 1st world problem) at least once a month so really trying to avoid this issue. Any input would be greatly appreciated 🙃
May 31, 20242 yr Author 1 hour ago, hilt_ctn said: Slipx added some code a while back that will enable you to sync your inverter time with HA instead #Set the interval to sync your inverter time with HA or comment out to disable It will at the very least remove this ( proving to be ) unreliable variable. And you won't experience clock drift as a result of turning off completely. So all you need do is update your ESP code Hey, Nice chatting here and not on MyBB Thanks so much... I can't find the code... @slipx would you mind sharing?
May 31, 20242 yr 1 hour ago, Muttley said: Hey, Nice chatting here and not on MyBB Thanks so much... I can't find the code... @slipx would you mind sharing? Howdy howdy ! https://github.com/slipx06/Sunsynk-Home-Assistant-Dash/tree/main You'll see the yaml's at the top of the page
May 31, 20242 yr There are two approaches. Using a set interval or manual method using a toggle #Set the interval to sync your inverter time with HA or comment out to disable interval: - interval: 3600s then: - lambda: |- esphome::modbus_controller::ModbusController *controller = id(inverter); time_t now = ::time(nullptr); struct tm *time_info = ::localtime(&now); int seconds = time_info->tm_sec; int minutes = time_info->tm_min; int hour = time_info->tm_hour; int day = time_info->tm_mday; int month = time_info->tm_mon + 1; int year = time_info->tm_year; year = year + 1900; int year1 = year - 2000; uint16_t reg22_value = (year1 << 8) | month; uint16_t reg23_value = (day << 8) | hour; uint16_t reg24_value = (minutes << 8) | seconds; if (year != 1970) { std::vector<uint16_t> rtc_data = {reg22_value, reg23_value, reg24_value}; esphome::modbus_controller::ModbusCommandItem set_rtc_command = esphome::modbus_controller::ModbusCommandItem::create_write_multiple_command(controller, 22, rtc_data.size(), rtc_data); controller->queue_command(set_rtc_command); ESP_LOGI("Time Sync", "Seconds: %d, Minutes: %d, Hour: %d, Day: %d, Month: %d, Year: %d", seconds, minutes, hour, day, month, year); } ############################################### BINARY SENSORS ######################################## binary_sensor: - platform: homeassistant # Manual Time sync. Create an input_boolean sensor in HA entity_id: input_boolean.sync_inverter_time name: "Sync Time" id: sync_time on_press: then: - lambda: |- esphome::modbus_controller::ModbusController *controller = id(inverter); time_t now = ::time(nullptr); struct tm *time_info = ::localtime(&now); int seconds = time_info->tm_sec; int minutes = time_info->tm_min; int hour = time_info->tm_hour; int day = time_info->tm_mday; int month = time_info->tm_mon + 1; int year = time_info->tm_year; year = year + 1900; int year1 = year - 2000; uint16_t reg22_value = (year1 << 8) | month; uint16_t reg23_value = (day << 8) | hour; uint16_t reg24_value = (minutes << 8) | seconds; if (year != 1970) { std::vector<uint16_t> rtc_data = {reg22_value, reg23_value, reg24_value}; esphome::modbus_controller::ModbusCommandItem set_rtc_command = esphome::modbus_controller::ModbusCommandItem::create_write_multiple_command(controller, 22, rtc_data.size(), rtc_data); controller->queue_command(set_rtc_command); ESP_LOGI("Time Sync", "Seconds: %d, Minutes: %d, Hour: %d, Day: %d, Month: %d, Year: %d", seconds, minutes, hour, day, month, year); }
May 31, 20242 yr Author 9 minutes ago, slipx said: There are two approaches. Using a set interval or manual method using a toggle #Set the interval to sync your inverter time with HA or comment out to disable interval: - interval: 3600s then: - lambda: |- esphome::modbus_controller::ModbusController *controller = id(inverter); time_t now = ::time(nullptr); struct tm *time_info = ::localtime(&now); int seconds = time_info->tm_sec; int minutes = time_info->tm_min; int hour = time_info->tm_hour; int day = time_info->tm_mday; int month = time_info->tm_mon + 1; int year = time_info->tm_year; year = year + 1900; int year1 = year - 2000; uint16_t reg22_value = (year1 << 8) | month; uint16_t reg23_value = (day << 8) | hour; uint16_t reg24_value = (minutes << 8) | seconds; if (year != 1970) { std::vector<uint16_t> rtc_data = {reg22_value, reg23_value, reg24_value}; esphome::modbus_controller::ModbusCommandItem set_rtc_command = esphome::modbus_controller::ModbusCommandItem::create_write_multiple_command(controller, 22, rtc_data.size(), rtc_data); controller->queue_command(set_rtc_command); ESP_LOGI("Time Sync", "Seconds: %d, Minutes: %d, Hour: %d, Day: %d, Month: %d, Year: %d", seconds, minutes, hour, day, month, year); } ############################################### BINARY SENSORS ######################################## binary_sensor: - platform: homeassistant # Manual Time sync. Create an input_boolean sensor in HA entity_id: input_boolean.sync_inverter_time name: "Sync Time" id: sync_time on_press: then: - lambda: |- esphome::modbus_controller::ModbusController *controller = id(inverter); time_t now = ::time(nullptr); struct tm *time_info = ::localtime(&now); int seconds = time_info->tm_sec; int minutes = time_info->tm_min; int hour = time_info->tm_hour; int day = time_info->tm_mday; int month = time_info->tm_mon + 1; int year = time_info->tm_year; year = year + 1900; int year1 = year - 2000; uint16_t reg22_value = (year1 << 8) | month; uint16_t reg23_value = (day << 8) | hour; uint16_t reg24_value = (minutes << 8) | seconds; if (year != 1970) { std::vector<uint16_t> rtc_data = {reg22_value, reg23_value, reg24_value}; esphome::modbus_controller::ModbusCommandItem set_rtc_command = esphome::modbus_controller::ModbusCommandItem::create_write_multiple_command(controller, 22, rtc_data.size(), rtc_data); controller->queue_command(set_rtc_command); ESP_LOGI("Time Sync", "Seconds: %d, Minutes: %d, Hour: %d, Day: %d, Month: %d, Year: %d", seconds, minutes, hour, day, month, year); } Awesome stuff.. Gonna copy pasta this in Thanks as always!
