Pylontech
What about battery #11 - that one is working okay? You might use BatteryView for checking that. But you would need RJ-11 usb to serial cable...
  • Replies 54
  • Views 6k
  • You can only have 7 of the US3000A in daisy chained. If you look in the manual for the 3000C it gives the positions for the different types.. For banks you can use the RS485 as shown in the manua
  • Just a note for the curious: Ports A/CAN and B/RS485 on the US3000C are having both protocols in each port. So the A is technically CAN+RS485, B is CAN+RS485 too. Daisy chaining of mult
  • That really depends on the inverter. If the inverter wants RS485 as BMS input, you can skip the LV-HUB in the last step. That's the case for Axperts, for example. If the inverter wants CAN B
As soon as I turn that battery on the batteries keep restarting. So I have kept it off. It looks like it is affecting the system. I think if those 2 faulty US3000A are swopped out for US3000C, then I will be able to bring battery 11 back into the flow of things....
11th battery has to be totaly separate, in terms of data communication. Nothing in its LinkPorts0/1, nothing in CAN/RS485 ports.Only Console port can be connected to a computer with BV or SA running.
But since you dont have RJ11 console cable, you can do just like you said - put it in the group, after you remove those 2 bad.
4 minutes ago, Simon M. said:
Yeah nothing was connected to it bar the positive and negative electric cables. There was no comms or anything.
Is it's SOC vastly different?
