May 3, 201610 yr That is not Infini SolarPower I decompiled but the Axpert one. When I have time again one day I will look at the infini software. To busy with real work.
May 3, 201610 yr 36 minutes ago, jdp said: When I have time again one day I will look at the infini software. Wow - that would be cool!
May 3, 201610 yr Hey Guys Hope Great, Can we put these long lines of codes in a txt file and upload rather, Will look great and neat, Sincerely Jason
May 4, 201610 yr Thx for the valuable infos. On base of this I created a polling programm already, but my logger needs the total Wh. Unfortunately only QET (total power in KW) and QED (daily power in Wh) work with my infini. QEY(year), QEM(month)... just reply zero. So I have to create my own counter (in Wh) in the software :-(
May 5, 201610 yr Any one posting data to emoncms with ihe infini? Sent from my SM-G920F using Tapatalk
June 22, 20197 yr Hello @StephanT I have an Infinisolar V 5 KW inverter and it has two communication ports on it, one is a USB port and the other is a RJ 45 style RS 232 port. I have tried connecting to it using a USB to Serial Converter which converts my Laptops USB to Serial and the resulting serial port is connected to inverters RJ 45 style RS 232 Port. I have tried both straight and null modem configurations. and i send the commands in ASCII format using 232analyzer software. nothing works. Inverter just wont talk. can you share the pictures of the cables that you used. Unfortunately, i dont have programming back ground but i understand enough to be able to learn from what is available of the web. I would really appreciate it if you can give some details into the cables used, ports involved (computer and inverter) and some basic information on connecting both together. I know i am asking for a lot but i would be really thankful if you can guide me. Thanks
July 21, 20205 yr On 2016/05/04 at 1:02 PM, riogrande75 said: Thx for the valuable infos. On base of this I created a polling programm already, but my logger needs the total Wh. Unfortunately only QET (total power in KW) and QED (daily power in Wh) work with my infini. QEY(year), QEM(month)... just reply zero. So I have to create my own counter (in Wh) in the software 😞 Hi, how to query QED? I tried QEDyyyymmdd without result, only "NAKss" Thanks! Elia
