infinisolar 3k Plus realtime values and logging
That is not Infini SolarPower I decompiled but the Axpert one.
When I have time again  one day I will look at the infini software. To busy with real work.
Thx for the valuable infos.
On base of this I created a polling programm already, but my logger needs the total Wh.
Unfortunately only QET (total power in KW) and QED (daily power in Wh) work with my infini. QEY(year), QEM(month)... just reply zero. So I have to create my own counter (in Wh) in the software :-(
Any one posting data to emoncms with ihe infini?
  • 3 years later...
Hello @StephanT
I have an Infinisolar V 5 KW inverter and it has two communication ports on it, one is a USB port and the other is a RJ 45 style RS 232 port. I have tried connecting to it using a USB to Serial Converter which converts my Laptops USB to Serial and the resulting serial port is connected to inverters RJ 45 style RS 232 Port. I have tried both straight and null modem configurations. and i send the commands in ASCII format using  232analyzer software.  nothing works. Inverter just wont talk. can you share the pictures of the cables that you used.
Unfortunately, i dont have programming back ground but i understand enough to be able to learn from what is available of the web. I would really appreciate it if you can give some details into the cables used, ports involved (computer and inverter) and some basic information on connecting both together.
I know i am asking for a lot but i would be really thankful if you can guide me.
  • 1 year later...
Unfortunately only QET (total power in KW) and QED (daily power in Wh) work with my infini. QEY(year), QEM(month)... just reply zero. So I have to create my own counter (in Wh) in the software 😞
Hi, how to query QED? I tried QEDyyyymmdd without result, only "NAKss"
Thanks!
Elia
