Goodwe
  • Replies 55
  • Views 13.5k
  • Goodwe fan in the house.   All in one solution that works right out the box. Perfect solution for your average users. Simple to install and to configure. Overall cost after in
  • Most pre paid meters are ok with the small short duration back feed if the inverter is set to zero export
  • I think we need to start looking long term. Also note they are not the same . they are 2 different type of inverters for different applications. GoodweES Installs 147 Victron Install 39
20 hours ago, SilverNodashi said:
Don't you have a 80A breaker?
No. If our efforts to convince the CoCT to find some compromise for the already installed Inverters fails I will then as a last resort apply for an 80A supply.
Victron Install 39
Goodwe In Gaurentee faults 9. replaced 7 still fight with them on the other 2 (does not seem i will get them resolved)
Victron Faults 3. Claims all 3 no problem.
Goodwe out of warantee Claims 7: Assistance with any sort of repairs or process to repair. ZERO
Victron out of warantee 3. 72 hours repairs done and system working.very reasonable costs
so as i HUGE supporter of GoodWe and porably one of the first to install goodwe in SA. I will no longer support this brand.
It does not help you have a good built product that is solid and looks good and works well ... in the beginning but you have NO after sales support AT ALL.
And gents if you have by chance imported this unit by yourself. You will be able to do a warantee claim... FROM CHINA. you will have to pay for all cost to get the machine here including import duties..
Would very much like to have a conversation with you. I’m having issues with my GoodWe and want to throw it into the ocean. The after sales is non existent!!! Please can you contact me via email on
[email protected]
Victron Install 39
Do you think this has to do with your supplier on this one?  The wankers in strydom park? 🙂
As an end user I witnessed my reseller fight with their incompetence for months to look at my equipment after GoodWe in China told them to replace it. Absolutely useless.
  • 1 year later...
My Goodwe inverter throttles the charge coming from my PVs, when the load usage from the home is low.
In other words it does send charge to my Tesla Power Wall 2 unless the is a significant load eg. 1KW plus.
Had anyone got the same problem. I am concerned the Goodwe will just  walk away when the warranty expires in about 4 months time.
The installer and supplier have not managed to get a satisfactory answer or solution from Goodwe.
I would appreciate some input.
  • 6 months later...
