April 24, 20197 yr I have been following our great forum for quite sometime now and realised a lot of people use fuses insteady of dc breakers. From my Electrical knowledge as a qualified electrician, the breaker has more advantages over the fuse. Is there any advantage that I might not be aware of which makes the fuse a darling to so many(besides quick reaction and lower price). I have been playing videos on youtube and realised in US they use dc breakers(midnight dc breakers etc) more than they do with fuses. I do realise even the hardwares here in SA dont have much of dc breakers.
April 24, 20197 yr @phoenix752, I agree with you and use DC MCB sub 100A. 46 minutes ago, phoenix752 said: Is there any advantage that I might not be aware of which makes the fuse a darling to so many SMA advocates that there should be a gap between MCB's for heating because they run full tilt. YMMV. However, when it comes to the 300A inverter inputs I use fuses. ( Not that I have ever-priced a 300A DC MCB, I think they fall into the "if you have to ask the price..." category.
April 25, 20197 yr The only advantages that a circuit breaker presents (talking specifically about MCB`s) is that they are convenient in that you can visually see which breaker has tripped and then to reset the breaker you simply flick a switch. But in DC applications where you have batteries with extremely high short circuit currents the breaking time of the correct fuse is unmatched by a circuit breaker. From a safety point of view fuses are the way to go if they are specified correctly and installed correctly. Circuit breakers contacts can also weld together and then your cables becomes a slow blow fuse
April 25, 20197 yr Author 1 hour ago, Jaws said: The only advantages that a circuit breaker presents (talking specifically about MCB`s) is that they are convenient in that you can visually see which breaker has tripped and then to reset the breaker you simply flick a switch. But in DC applications where you have batteries with extremely high short circuit currents the breaking time of the correct fuse is unmatched by a circuit breaker. From a safety point of view fuses are the way to go if they are specified correctly and installed correctly. Circuit breakers contacts can also weld together and then your cables becomes a slow blow fuse Oooh ok..so its all about the reaction time of fuses. Wonder why most appliances have built in fuses
April 25, 20197 yr 7 minutes ago, phoenix752 said: Oooh ok..so its all about the reaction time of fuses. Wonder why most appliances have built in fuses I think is mainly about the cost. If you look at Large Lead Acid battery installations with high ISSC ratings even a "small" 40 A circuit breaker is "BIG" in physical size and then also relatively expensive. Descrimination DC 24-48V.pdf
April 25, 20197 yr Author 20 minutes ago, Jaws said: I think is mainly about the cost. If you look at Large Lead Acid battery installations with high ISSC ratings even a "small" 40 A circuit breaker is "BIG" in physical size and then also relatively expensive. Descrimination DC 24-48V.pdf 2.42 MB · 3 downloads I get you Jaws. But in terms of cost I think fuses are costly in the long run in the sense that you have to change it after every faulty. But breakers is a matter of reseting and you are back online. I know of a guy who installed two axpects (48/5000VA) in parralel running from 4 Pylontech US2000 protected by a 80A fuse(he is amateur electrician of course). Each inverter had 9×JA solar 330s and the installation runs for about 5 days before the fuse blew up. So I think the fuses are not as efficient in real world as on paper. Because the 80A mark was surpassed so often it should have blown in matter of minutes
April 25, 20197 yr 2 hours ago, Jaws said: Circuit breakers contacts can also weld together and then your cables becomes a slow blow fuse Fuses have a definitive degree of certainty about them, that an MCB doesn't. I know I said I used MCB's for sub 100A, I retract that, I had forgotten I have fuses on the battery strings. I consider the batteries as the real source of oomph in the system.
April 25, 20197 yr 2 hours ago, phoenix752 said: costly in the long run Only if you constantly blow them... I haven't blown a fuse in the last 6 years. So they definitely represent both a cost saving and a bit more safety.
