July 17, 20197 yr Hi Guys COJ incorrectly billed me, they did an estimated reading on my electricity bill, they are saying I used 70kwh per day my actual reading is 25kwh a day. They dont answer phones very frustrating
July 17, 20197 yr Author Suppose to add more.... hit send by mistake Does anyone have a contact at COJ who can assist ?
July 17, 20197 yr Eskom used to do that to me. Never read the meter, bizarre estimates etc etc. Fortunately that is a dim and distant memory!
July 17, 20197 yr Ours is also quite high this month, don't know what is going on. Used to be around 39/day but this month it is at 59/day.
July 17, 20197 yr Author 1 hour ago, Luminous said: Ours is also quite high this month, don't know what is going on. Used to be around 39/day but this month it is at 59/day. Check your bill if its estimated reading... If it is that's most likely why its high. Compared estimated reading to current reading
July 17, 20197 yr 7 hours ago, Treschen said: Hi Guys COJ incorrectly billed me, they did an estimated reading on my electricity bill, they are saying I used 70kwh per day my actual reading is 25kwh a day. They dont answer phones very frustrating Where do you live? Some wards have very active, very helpful counsellors, some do not. Check the latest tariffs and see if you'd save if you were on prepaid. Then the whole problem of estimated readings goes away. Even if you're only breaking even, it's worth it for that. They may still come to check your meter, but they are just checking that it is present and that the serial number matches their records, and that it hasn't been bypassed.
