divhy Posted July 17, 2019 Share Posted July 17, 2019 hi, am planning to run the 0.75kw borehole pump on this system 5kva expert inverter 9*330w panels 1* 100ah lithium battery can this system be able to run that pump with no other loads on the system thanks Quote Link to comment Share on other sites More sharing options...
0 Jaco De Jongh Posted July 17, 2019 Share Posted July 17, 2019 34 minutes ago, divhy said: can this system be able to run that pump with no other loads on the system It should handle the startup current with ease, running it should not be a problem at all. Quote Link to comment Share on other sites More sharing options...
0 GVC Posted July 17, 2019 Share Posted July 17, 2019 I have tha same size pump on my JoJo tank and my Axpert 5kva runs it as well as the rest of the house with no problems. Quote Link to comment Share on other sites More sharing options...
0 DeepBass9 Posted July 18, 2019 Share Posted July 18, 2019 (edited) Easily. I have the same sized pump and similar sized system. The 0.75kw is a maximum power, it may not neccesarily draw that amount of power in your application, depending on the head the pump is working against. If run it during the day, it will use no battery power and run straight from solar. Edited July 18, 2019 by DeepBass9 Quote Link to comment Share on other sites More sharing options...
Question
divhy
hi,
9*330w panels
thanks
3 answers to this question
