July 17, 20197 yr hi, am planning to run the 0.75kw borehole pump on this system 5kva expert inverter 9*330w panels 1* 100ah lithium battery can this system be able to run that pump with no other loads on the system thanks
July 17, 20197 yr 34 minutes ago, divhy said: can this system be able to run that pump with no other loads on the system It should handle the startup current with ease, running it should not be a problem at all.
July 17, 20197 yr I have tha same size pump on my JoJo tank and my Axpert 5kva runs it as well as the rest of the house with no problems.
July 18, 20197 yr Easily. I have the same sized pump and similar sized system. The 0.75kw is a maximum power, it may not neccesarily draw that amount of power in your application, depending on the head the pump is working against. If run it during the day, it will use no battery power and run straight from solar. Edited July 18, 20197 yr by DeepBass9
