Home assistant questions
I hope someone van help, I am struggling to get a TP link smartplug be visible in home assistant. I can connect to it via its own app and switch on and off. I have got its IP address and can ping so that seems OK.
The internet tells me if I put these lines in my configuration.yaml file the switch should be visible in the UI, but nothing.
switch:
  - platform: tplink
    host: 192.168.2.101
What am I missing?
is there a specific order that things need to be in the yaml file?
Edited by DeepBass9
  • Replies 60
  • Views 11.5k
switch:
  - platform: tplink
    host: 192.168.2.101
What am I missing?
Did you add the integration part? Configuration -> Integration -> "+" and select tplink?
I did. But it still doesn't work.
I have other network problems to sort out first though. I have a mixed windows and linux network which is a nightmare (to a network ignoramus)
Maybe someone can help, I am getting nowhere with HA. I have it running on a PI with a fixed ip address of 192:168:0.111 . This is on a wired network. I have a wireless access point, connected to the switch, with address192.168.2.1 and a test TP link switch and a sonoff connected via ewelink. If I have my tablet connected to the wireless, I can switch both the switches on and off using their own apps.
I can't see either switches from the wired network, and so the pi doesn't see them either. What am I doing wrong?
Best I would say is to try and keep the IP range the same, disable the dhcp on the 192.168.2.1. And just run everything of the 192.168.0.111 dhcp. Or change your Pi to also get the ip from the 192.168.2.1 dhcp
I agree keeping all the devices on the same network/subnet/IP range (at first at least). This will make troubleshooting a bit easier.
To get back to the initial issue. If you go to developer tools > states, do you see the entity for the TP Link? It think it should be switch.switcheroo unless the TP Link integration does something else with it. If you see it you could try adding a switch or an entity to the frontend if you use the LovelaceUI.
I am using a hybrid of Lovelace and old legacy config files so I am not always sure where the legacy config stops working and Lovelace takes over.
Edited by vlan_one
I am still stuck at the point of getting the Pi to connect to the internet. very annoying, it initially worked, but now not. I have the pi plugged into a wired network on a fixed IP address, and I can see the HA app from either the wired or wireless AP. It seems there is a problem with DNS as the pi can't find anything on the internet, so that default installed weather service cannot be connected to. But if I install a component from the internet, then it is found and installed.
So I get this:
The log file shows :
Tue Jul 30 2019 12:17:04 GMT+0200 (South Africa Standard Time)
https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/1.9/ returned Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None [Try again]
And similar for anything else it has to find on the internet.
Any ideas anyone?
You look really at the start of your HA setup. Format the SD card with the new software version. Plug the sd card in, network cable and then the power.
Give it 20min and then access the url it gets from the router. If you don't know what IP the device got, load Fing app on your phone and it will scan all the devices on the network and tell you the IP.
It should be connected to the internet and most of the stuff will start to work.
I am moving backwards from that point. The 'should be connected to the internet' is where it all falls down.
I have the IP addresses of various devices so once I get the internet connection sorted out, maybe I can move forward. I am using this my-network file to set up the static IP address :
[connection]
id=HassOS default
uuid=8e923b56-c1c0-48b7-9a13-7de2ebd4be6e
type=802-3-ethernet
[ipv4]
method=manual
address=192.168.0.111/24,192.168.2.1
dns=8.8.8.8,8.8.4.4,127.0.1.1,192.168.0.1
[ipv6]
addr-gen-mode=stable-privacy
method=auto
I have no done a fresh install using wifi network. It took a long time but is done. Below is the log, and I don,t see any network access errors. It pulls the hassio image and configurator image with no problem.
19-07-31 01:45:59 INFO (MainThread) [__main__] Initialize Hass.io setup
19-07-31 01:46:06 INFO (MainThread) [__main__] Setup HassIO
19-07-31 01:46:06 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 170
19-07-31 01:46:06 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
19-07-31 01:46:08 INFO (SyncWorker_0) [hassio.docker.interface] Cleanup images: ['homeassistant/armv7-hassio-supervisor:163']
19-07-31 01:46:10 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-07-31 01:46:10 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-07-31 01:46:10 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-07-31 01:46:11 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-07-31 01:46:11 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-07-31 01:46:11 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: de.pengutronix.rauc - /
19-07-31 01:46:11 INFO (MainThread) [hassio.host.info] Update local host information
19-07-31 01:46:11 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-07-31 01:46:11 INFO (MainThread) [hassio.host.services] Update service information
19-07-31 01:46:11 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-07-31 01:46:11 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-07-31 01:46:11 INFO (MainThread) [hassio.host.services] Reload local service hassos-apparmor.service
19-07-31 01:46:11 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-07-31 01:46:11 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version landingpage
19-07-31 01:46:11 INFO (MainThread) [hassio.hassos] Detect HassOS 2.12 on host system
19-07-31 01:46:11 INFO (SyncWorker_0) [hassio.docker.hassos_cli] Found HassOS CLI homeassistant/armv7-hassio-cli with version 11
19-07-31 01:46:12 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-07-31 01:46:12 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-07-31 01:46:12 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-07-31 01:46:12 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-07-31 01:46:12 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-07-31 01:46:21 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-07-31 01:46:21 INFO (MainThread) [hassio.discovery] Load 0 messages
19-07-31 01:46:21 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-07-31 01:46:21 INFO (MainThread) [__main__] Run Hass.io
19-07-31 01:46:21 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-07-31 01:46:21 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-07-31 01:46:21 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-07-31 01:46:21 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-07-31 01:46:21 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
19-07-31 01:46:21 INFO (SyncWorker_0) [hassio.docker.interface] Restart homeassistant/raspberrypi3-homeassistant
19-07-31 01:46:28 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-31 01:46:28 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-07-31 01:46:28 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-07-31 01:46:28 INFO (MainThread) [hassio.core] Hass.io is up and running
19-07-31 01:46:28 INFO (MainThread) [hassio.homeassistant] Setup Home Assistant
19-07-31 01:46:28 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.96.5.
19-07-31 01:55:11 INFO (SyncWorker_3) [hassio.docker.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.96.5 as latest
19-07-31 01:55:11 INFO (MainThread) [hassio.homeassistant] Home Assistant docker now installed
19-07-31 01:55:11 INFO (MainThread) [hassio.homeassistant] Start Home Assistant
19-07-31 01:55:11 INFO (SyncWorker_8) [hassio.docker.interface] Stop homeassistant application
19-07-31 01:55:16 INFO (SyncWorker_8) [hassio.docker.interface] Clean homeassistant application
19-07-31 01:55:17 INFO (SyncWorker_8) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.96.5
19-07-31 01:55:53 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-31 01:55:53 INFO (SyncWorker_17) [hassio.docker.interface] Cleanup images: ['homeassistant/raspberrypi3-homeassistant:landingpage']
19-07-31 03:22:59 INFO (MainThread) [hassio.addons] Create Home Assistant add-on data folder /data/addons/data/core_configurator
19-07-31 03:22:59 INFO (SyncWorker_4) [hassio.docker.interface] Pull image homeassistant/armv7-addon-configurator tag 3.4.
19-07-31 03:24:41 INFO (SyncWorker_4) [hassio.docker.interface] Tag image homeassistant/armv7-addon-configurator with version 3.4 as latest
19-07-31 03:24:44 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-07-31 03:24:44 INFO (MainThread) [hassio.ingress] Update Ingress as panel for core_configurator
But still none of the entities are able to connect to the internet, I still get errors like this:
Log Details (ERROR)
Wed Jul 31 2019 05:20:19 GMT+0200 (South Africa Standard Time)
Log Details (ERROR)
Wed Jul 31 2019 04:55:46 GMT+0200 (South Africa Standard Time)
Could not contact Home Assistant Update to check for updates
Log Details (ERROR)
Error doing job: Task exception was never retrieved
Traceback (most recent call last):
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 825, in _resolve_host
    self._resolver.resolve(host, port, family=self._family)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/resolver.py", line 30, in resolve
    host, port, type=socket.SOCK_STREAM, family=family)
  File "uvloop/loop.pyx", line 1464, in getaddrinfo
socket.gaierror: [Errno -3] Try again
Possible, but I have no clue how to set that up.  My networking knowledge is just about non existent! I thought it was maybe DNS, as HASSIO is probably looking on the internet for an IP address, but when a url is used then it fails.
Edited by DeepBass9
18 hours ago, DeepBass9 said:
[ipv4]
method=manual
It seems your default gateway is incorrect. If your Pi is in .192.168.0.0/24 subnet then there is no way to get to 192.168.2.1. Try and change your gateway to 192.168.0.1 (or whatever your router IP Address is)
So ELI5, all of the adresses on the wired network are 192.168.0.XX. The addresses on the wireless part of the network are 192.168.2.XX. When I had the pi on the wired network with 192.168.0.111 as a static IP, it was visible on wired and wireless. Now I have used the following my-network file to get it up on wireless. Now I can see it on the wireless part of the network, but not from wired:
Initially when it worked, thinking about it now, I had it connected with a network cable to the wireless AP and it came up with 192.168.2.XX address, could connect to the internet but was invisible from the wired side.
[connection]
id=HassOS default
uuid=8e923b56-c1c0-48b7-9a13-7de2ebd4be7e
type=802-11-wireless
[wifi]
mode=infrastructure
ssid=dreamlodge
[wifi-security]
auth-alg=open
key-mgmt=wpa-psk
psk=DeepBass9
[ipv4]
method=auto
[ipv6]
method=auto
Trying this now with wired connection :
[connection]
id=HassOS default
type=ethernet
interface-name=eth0
permissions=
secondaries=
[ipv4]
method=manual
address=192.168.0.111/24,192.168.0.1
dns=8.8.8.8,8.8.4.4
dns-search=
[ipv6]
method=auto
Is there a reason the wired and wifi is on a different IP range?
DNS looks like google, is this hard coded in your router setup?
Please draw us a picture, I think you setup is over complicated with multiple ranges
4 minutes ago, DeepBass9 said:
192.168.0.4  is the internet modem
According to your ipconfig output this is your laptop IP and your router should be 0.1 for the wired network.
Can you ping the Google DNS server from the pi?
I don't know how to do that.
sorry for the assumption. if you are able to get onto a SSH terminal window of HASS, just issue the command ping 8.8.8.8 and see if you get a reply.
Edited by vlan_one
Still getting nowhere with this issue.
I.m trying to install SSH on the pi but get this error:
19-07-31 05:28:45 INFO (SyncWorker_17) [hassio.docker.interface] Pull image homeassistant/armv7-addon-ssh tag 6.0.
19-07-31 05:28:45 ERROR (SyncWorker_17) [hassio.docker.interface] Can't install homeassistant/armv7-addon-ssh:6.0 -> 500 Server Error: Internal Server Error ("Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1]:49822->[::1]:53: read: connection refused").
The time I would save by automating things compared to the time I have wasted on home assistant are rapidly becoming indistinguishable.
