July 24, 20197 yr On 2019/07/20 at 11:56 AM, Mark said: I think its worth adding a hanger bolt in the centre of the 3200 or moving the side bolts towards the centre. Correct. At least one bolt every 1.2 meters is my rule. Might be a tad overkill but better over than under.
August 4, 20197 yr Author Well the 10 panels are on! Thanks @Jaco de Jongh for the mounting hardware and advice. Excellent service! Edited August 4, 20197 yr by deapsquatter
October 30, 20205 yr On 2019/07/19 at 9:27 PM, Jaco De Jongh said: Renusol.. Great German Product. Installed as indicated below: Also get them for your roof type, Mounts through the top part of the profile, with a storm washer as well as a rubber seal. 99% chance it will be underneath a panel and that the IBR will be at an angle. All contributing factors to make it leak free. The complete system will consist of the following spares. What is the Renusol storm washer used for and where does it go? I can't find any depiction of how it's used online. Is it a fancy seal that is sandwiched between the hangar bolt and roof sheet to help prevent leaks? If so what is the purpose of the rubber seal on the hanger bolt in that case?
October 30, 20205 yr 1 hour ago, Surge said: What is the Renusol storm washer used for and where does it go? I can't find any depiction of how it's used online. Is it a fancy seal that is sandwiched between the hangar bolt and roof sheet to help prevent leaks? If so what is the purpose of the rubber seal on the hanger bolt in that case? I just left it out when I did my install. I also couldn't figure out where it was meant to go.
February 7, 20251 yr Dumb newbie question: I want to use those triangle mounts, also to get a better angle especially during winter. In the drawing above (by Jaco) there are 2 rails horisontally across the triangle mounts, with then 3 panels in portrait on top. Are these rails necessary? If the panels are mounted in landscape, with maybe two of these triangle mounts each - would rails still be required? Coupled to this question: Are panels structurally strong enough for e.g. the wind storms? Or are they brittle and do not form part of the structural rigidity of the installation? (Meaning you need lots of rails etc. When I see a panel is only secured in 4 points, makes me assume the panel itself is wind proof. I ask because e.g. my old school solar water collectors (geyser) are held at a 45degree angle (correct for winter sun in Cape Town) but only a rod at each high corner (and short brackets at the low corners. These 4 points are mounted on a rail, but that had more to do with where the holes through the (flat) tiles would hit wood beams. So the panel is basically suspended by its 4 corners, at 45degrees, in Cape Town winds, no problem. Could one expect the same from PV panels or do that require rigid structural support? Thanks! Leon
