November 12, 20196 yr Hello My father in law Solar is using Axpert 5Kw inverter. Once in a while the PV side just stops charging. The supplier supplied me with new firmware. Looking a the file supplied, it looks like it is version 74.40 (Folder name in Zip file is AxpertMKS5K74.40P) Anyone know of any potential issues upgrading from 72.20 to 74.40? Thanks
November 12, 20196 yr On 2019/11/12 at 4:50 PM, ProjectGKR said: Anyone know of any potential issues upgrading from 72.20 to 74.40? I believe that you'll lose the ability to charge the battery beyond 58.4 V. It's also not obvious to me that a firmware seemingly designed for a 1:8 transformer (74.40) will even work properly and safely in hardware that seemingly has a 1:7 transformer (your machine that came with 72.20). If you do attempt this, please let us know how it goes. Edit: I now realise that this won't work at all; see this post. Edited November 17, 20196 yr by Coulomb
November 12, 20196 yr Author 1 hour ago, Coulomb said: I believe that you'll lose the ability to charge the battery beyond 58.4 V. It's also not obvious to me that a firmware seemingly designed for a 1:8 transformer (74.40) will even work properly and safely in hardware that seemingly has a 1:7 transformer (your machine that came with 72.20). If you do attempt this, please let us know how it goes. The system is running on AGM 200ah, but might first need to get hold of another inverter before attempting it as it is an off grid system and eskom option
November 12, 20196 yr Hi. Do you have the cables to do a upgrade?? I also need to do a upgrade. But cant find the right adaptors!!! Laptop does not pick up the inverter!!
November 13, 20196 yr 13 hours ago, Boertjie. said: But cant find the right adaptors!!! Hi Boertjie, when i last did a firmware upgrade on a Voltronic I used a normal USB to Serial Converter together with the cables supplied with the inverter. I guess it will still work.
November 13, 20196 yr Hi. I have tried two different ones no luck. Let me maybe see if i can get another one. Thanx.
November 13, 20196 yr 2 hours ago, Boertjie. said: Hi. I have tried two different ones no luck What cable do you connect to this adapter? (The one connecting to the inverter?)
November 13, 20196 yr 50 minutes ago, Jaco de Jongh said: What cable do you connect to this adapter? (The one connecting to the inverter?) Hi. The cable supplied with the inverter. It is possible csn we maybe have a chat on whatsup or so? 0741111369
November 17, 20196 yr Author On 2019/11/13 at 9:48 AM, Boertjie. said: Hi. I have tried two different ones no luck. Let me maybe see if i can get another one. Thanx. I got hold of the cables that plugs into the serial port of the inverter (the RJ45 port). I still have a laptop with a serial port, which might make life easier as not all serial to usb converters play nice
November 17, 20196 yr 40 minutes ago, ProjectGKR said: I got hold of the cables that plugs into the serial port of the inverter (the RJ45 port). I still have a laptop with a serial port, which might make life easier as not all serial to usb converters play nice Hi. Thanx. I think i got hold of the right cable now. Waiting for it. Will be here on monday or teusday. But if not working can you whatsup me. Then i can arange with you. Thanx. 0741111369
November 17, 20196 yr Author 3 hours ago, Boertjie. said: Hi. Thanx. I think i got hold of the right cable now. Waiting for it. Will be here on monday or teusday. But if not working can you whatsup me. Then i can arange with you. Thanx. 0741111369 @Boertjie. Where are you based as I see on another post that you are trying to update to 72.70 from 72.40?
November 17, 20196 yr On 2019/11/12 at 4:50 PM, ProjectGKR said: Anyone know of any potential issues upgrading from 72.20 to 74.40? @ProjectGKR Sorry I didn't twig to this earlier. One of the potential issues is this: it simply won't work. By which I mean that the firmware update tool supplied with 74.40 is not compatible with the firmware 72.20; the PC will send the wrong command, and the firmware update will not proceed. If you attempt this, the machine will appear frozen, but will come good when the battery power is cycled. Switching the rocker switch off and on will do no good. As a point of interest, firmware version 72.20 (and I assume earlier and later versions of it, if the latter exist) are the only ones I know of with this "protection". Given that they went to all this trouble, I'd say that it's a really bad idea to attempt it. You need to get back to your supplier and remind them that your father in law's machine is a 64-volt capable inverter-charger model, and the firmware update file that they supplied just won't work. That's assuming that there are no typos in the firmware version numbers in your original post. Edited November 17, 20196 yr by Coulomb
November 18, 20196 yr Author 7 hours ago, Coulomb said: You need to get back to your supplier and remind them that your father in law's machine is a 64-volt capable inverter-charger model, and the firmware update file that they supplied just won't work. That's assuming that there are no typos in the firmware version numbers in your original post. Thanks for the feedback, will get into contact with the supplier.
November 19, 20196 yr On 2019/11/17 at 5:31 PM, ProjectGKR said: @Boertjie. Where are you based as I see on another post that you are trying to update to 72.70 from 72.40? Hi. Sorry i struggle with these posts. Might be a mistake. Skeerpoort. Close to hartbeespoortdam. I got my cable in the post this morning. So will see tonight. Hopefully ill come right
