October 28, 20205 yr Just now, HennieB84 said: From what I understand it's to do with the UP2500 battery, the cable only works with that configuration. Cool, thank you for your help!
October 28, 20205 yr Just now, meyerwh said: Cool, thank you for your help! No problem, hope you get everything sorted.
October 28, 20205 yr 2 minutes ago, HennieB84 said: No problem, hope you get everything sorted. I'll let you know.
July 2, 20215 yr I have a similar issue. I just purchased the Kodak VMIII inverter and a Pylontech us3000c battery. I am using the cable supplied with the inverter (and the side labeled PYLON is connected to the battery). I checked the pins to what is suggested in this forum and it seems to correspond. I have selected PYL as the battery type. I am still receiving the 61 error. Could it be possible that the us3000c has a different pinout?
