March 11, 20206 yr Hi I just finish installing my load shedding backup UPS system and switch it on, on Friday 6 Mar 2020. The system consists of the following: 1 x Axpert MKS 5KV Inverter, 1 x Shoto SDA10-48100M14 LiFeOP4 battery. My setup = the Inverter get's 220V from normal eskom plug in my house. Inverter is connected and 3 x Leads run from the output of the Inverter to DB box with main breaker, earth breaker, 3 x breaker for each lead to my (i) PC, Fibre Modem, Fan, (ii) TV, Dstv decoder, Fan, (iii) Bedroom TV, bedroom fan. T QUESTION: Is my Inverter LCD settings correct for my Shoto SDA10-48100M14 LiFeOP4 battery Current setting: Program 1 - Ut1 Program 2 - 10A Program 3 - APL Program 4 - SdS Program 5 - USE Program 6 - Lrd Program 7 - trd Program 9 - 50Hz Program 11 - 10A Program 12 - 50% Program 13 - 53 Program 16 - SNU Program 18 - bON Program 19 - hEP Prorgam 20 - LON Program 22 - AON Program 23 - bYE Program 25 - FEN Program 26 - 54,2 Program 27 - 53 Program 28 - Nothing Program 29 - 45 Program 30 - Nothing Program 31 - 5be Please help - want to get the most out of my battery and insure that it is charge correct. PLEASE HELP IF YOU CAN - I want to get the most out of my battery and must therefore be sure that it is charged correct.🙏
March 12, 20206 yr I'm going to guess that your battery is similar to a PylonTech US3000 [ edit: as per a later post, it's actually about 1.4 x a US3000, or 2x a US2000 ]. At bottom is my standard settings for PylonTechs. But you should check that your battery is 15S, like the PylonTechs; some are 16S (e.g. my home made LFP battery is 16S). So for you setting 02 would be 30, for example. I note that setting 26 is far too high (3.61 VPC). That's the extreme limit for LFP cells, and Axperts have a habit of overshooting their target voltage. Edited March 20, 20206 yr by Coulomb
March 19, 20206 yr On 2020/03/12 at 1:41 PM, Coulomb said: I'm going to guess that your battery is similar to a PylonTech US3000. At bottom is my standard settings for PylonTechs. But you should check that your battery is 15S, like the PylonTechs; some are 16S (e.g. my home made LFP battery is 16S). So for you setting 02 would be 30, for example. I note that setting 26 is far too high (3.61 VPC). That's the extreme limit for LFP cells, and Axperts have a habit of overshooting their target voltage. @Coulomb, if the Axpert (=Kodak) King does have Pylontech support (ie Q5 has option PYL) then would it be able to communicate with the Shoto battery mentioned in this post ? The Shoto does have a RS485 port. Information on this battery is virtually non-existent...
March 20, 20206 yr 14 hours ago, GreenMan said: if the Axpert (=Kodak) King does have Pylontech support (ie Q5 has option PYL) then would it be able to communicate with the Shoto battery mentioned in this post ? Unlikely, but possible. The PylonTechs are a sort of de-facto standard now, so it's possible that other manufacturers, especially the lesser known ones, might emulate the PylonTech protocol. But it's a long shot.
March 20, 20206 yr So this SHOTO is a 4.8 kW battery: - so about 2 x US2000 or 1.4 x US3000, so adjust accordingly. Battery spec can be found https://cdn.shopify.com/s/files/1/1776/7837/files/SDA10-48100_EN.pdf?1125. Edited March 20, 20206 yr by Sidewinder
