Axpert inverter RS232/Serial logic levels
Hi all
I was hoping I don't need to crack out the old OScope to figure this out, hopefully somewhere on here already has this on hand:
What are voltage levels of the RS232/Serial port on the Axpert?
Edited by Gnome
It's a standard RS232, therefore the voltage can be anywhere between -25V to +25V
Long story short -USB to TTL cable converter is NOT suitable. You need a proper USB to RS232 converter.
Thanks guys.  I was hoping to connect to the Raspberry Pi without needing a MAX3232 but seems that is unavoidable.
At times you can get away with just resistors but the differential is too large and negative voltages is obviously a problem.
Edited by Gnome
