PV Panels watts in relation to voltage
Good day to all,
I had 3 Canadian solar panels (CS3W-400P), but now only have 2 due to a hail storm.
Pmax=400W
Vmp=38.7V
Imp=10.34A
Voc=47.2V
They were connected in series giving me about 1.2kW and 115V, give or take. Now with 2 panels connected in series I only get +/- 500W and 70V. Max input to the inverter is 145V.
I was expecting 800W, but is the lower voltage responsible for the lower wattage? I'm totally buggered at the moment due to the lock-down.
Is there a way to get more watts out of the panels as they are? or could it be that the hail impact on the 2 remaining panels caused something. They have no physical damage and the voltages seem right.
On a more or less similar note. My brother has a Growatt 3kw inv paired to 3x330w panels connected in parallel.
PV voltage it can handle is 100v and max pv watts is 1000w. He too is only getting about 500w at 32v on a good day, so I told him to connect it in series, but he told me the mppt controller should work things out.  I have checked the Voc on the sticker and its just below 100v. Did I just answer my own stupid question or is there more to it?
If Coulomb is reading this, thank you very much for all the input you have given on this forum.
Thanks for a great forum
ps. Anybody want a good second hand slightly used hail damaged solar panel? Willing to swop for toilet paper.
No. 70 V is perfectly fine for a 145 V max (130 V max for maximum power) solar charge controller.
I suspect you rarely got 1.2 kW from your nominally 1.2 kW panels. Usually the best you can expect near noon if the angles are good and no cloud or shading is about 80% of nominal, sometimes 75%. So that's around 600-640 W.
I suspect the other panels sustained some damage from the hail, even if not as visibly bad as the one in your photo. That might explain the last 100 or so watts.
Just now, Warlok said:
No physical damage on the panels. But we are on our way to Winter, and my panels need to be adjusted.
Yip, what you said is right. I've looked on pvout.org and it could only generate 1.2kw between 11am and 2pm on a good day in the middle of summer. Looks like I really need another string of panels.
24 minutes ago, JustinSchoeman said:
Some suppliers (eg Solar Man in Pretoria) are still open, but for spares and repairs only (under the essential maintenance provision).  So it should still be possible to order replacement panels during the lockdown.
Thanks Justin. Will take a look, but I would really like to support the power-forum store. https://powerforum-store.co.za/
Suppose it all depends on price...
